habe nun folgende Logs angefertigt, aus zeitlichen gründen aber leider ersteinmal nur als text.. sry! Aber vielleicht reicht das ja schon, um mir zu helfen..
Der Fehler tritt übrigens nicht immer an der im 2ten Log beschriebenen Stelle auf, manchmal früher, manchmal später..
028 906 021 GC ,,1.9l R4 EDC 00SG 1408,
Beschleunigung aus dem Stand, bis ca. 4500 U/min / 3. Gang:
,Group A:,'003,,,,Group B:,'008,,,,Group C:,'011
,,Engine speed,MAF (specified),MAF (actual),EGR duty cycle,,Engine speed,Inj qty,Inj qty,Inj qty,,Engine speed,Specified MAP,Actual MAP,Duty cycle
,TIME,861-945,240-340,240-340,4-84,TIME,,?,?,?,TIME,,,,Boost Valvle
MARKER,STAMP, /min, mg/R, mg/R, %,STAMP, /min, mg/R, mg/R, mg/R,STAMP, /min, mbar, mbar, %
,0.66,861,260.0,448.9,59.8,1.34,861,0.0,28.0,26.2,0.00,861,958.8,1020.0,91.6
,2.70,987,290.0,478.8,59.8,3.35,987,17.0,28.6,25.0,2.03,861,958.8,1020.0,91.6
,4.64,1953,850.0,558.6,4.8,5.28,2919,31.8,35.2,37.0,4.00,1239,1407.6,1030.2,42.6
,6.58,1680,255.0,525.4,27.9,7.23,1785,30.2,34.4,26.4,5.92,2268,1050.6,1193.4,62.6
,8.54,2037,250.0,694.9,4.8,9.20,1155,0.0,29.4,29.0,7.90,2100,1887.0,1152.6,35.1
,10.52,1428,850.0,538.6,4.8,11.19,1533,45.0,32.0,27.2,9.84,1323,979.2,1040.4,79.7
,12.50,1806,850.0,734.8,4.8,13.16,1995,43.4,35.4,37.6,11.86,1659,1856.4,1111.8,34.7
,14.44,2310,850.0,847.9,4.8,15.08,2499,41.8,35.2,38.0,13.80,2163,1887.0,1326.0,35.1
,16.38,2793,850.0,847.9,4.8,17.03,2940,40.6,35.2,37.0,15.73,2646,1866.6,1458.6,34.7
,18.33,3213,850.0,847.9,4.8,18.98,3360,39.6,34.8,36.6,17.68,3087,1866.6,1489.2,34.7
,20.33,3591,850.0,847.9,4.8,21.02,3717,39.0,34.2,36.8,19.66,3486,1866.6,1499.4,34.7
,22.30,3927,850.0,847.9,4.8,22.94,4032,38.4,34.4,36.4,21.66,3822,1856.4,1499.4,34.7
,24.22,4221,850.0,847.9,4.8,24.87,4326,38.0,30.6,35.4,23.58,4137,1846.2,1499.4,34.7
,26.17,4452,850.0,837.9,4.8,26.82,4515,37.6,25.4,33.0,25.52,4389,1785.0,1458.6,34.7
,28.12,4620,850.0,788.0,4.8,28.77,4200,0.0,32.0,30.4,27.47,4578,1734.0,1417.8,34.7
,30.11,1638,250.0,555.3,4.8,30.76,924,0.0,28.4,25.8,29.43,2688,1111.8,1162.8,54.6
,32.04,861,255.0,435.6,59.8,32.67,861,0.0,28.0,24.4,31.40,840,989.4,1030.2,66.5
,33.97,861,255.0,435.6,59.8,34.62,861,0.0,28.0,25.0,33.31,861,979.2,1020.0,74.1
Und nun direkt bis in den Notlauf, der bei ca. 140km/h eingetreten ist:
,1.30,1911,355.0,578.6,59.8,0.00,1848,4.6,35.2,24.6,0.64,1869,1264.8,1060.8,65.3
,3.22,2394,635.0,847.9,59.8,1.94,2016,14.8,35.4,28.6,2.58,2163,1642.2,1132.2,34.7
,5.19,1722,850.0,631.8,19.9,3.89,2667,19.2,35.2,37.6,4.53,1785,1030.2,1132.2,57.4
,7.14,2184,850.0,847.9,4.8,5.84,1869,40.0,35.2,34.0,6.49,2016,1917.6,1254.6,35.1
,9.09,2667,850.0,847.9,4.8,7.79,2352,41.2,35.2,38.0,8.43,2520,1887.0,1397.4,34.7
,11.07,1974,850.0,741.5,4.8,9.74,2835,36.8,35.2,37.2,10.40,2226,1071.0,1203.6,64.9
,13.01,2205,850.0,847.9,4.8,11.72,2058,40.4,35.2,37.8,12.35,2121,1917.6,1305.6,34.7
,14.97,2415,850.0,847.9,4.8,13.66,2268,39.8,35.2,38.2,14.32,2352,1907.4,1377.0,34.7
,16.89,2604,850.0,847.9,4.8,15.62,2478,39.4,35.2,38.0,16.25,2541,1897.2,1417.8,34.7
,18.83,2793,645.0,847.9,19.9,17.53,2667,39.2,35.2,37.6,18.19,2730,1897.2,1438.2,34.7
,20.82,2268,850.0,847.9,4.8,19.50,2100,0.0,35.2,32.4,20.18,2373,1907.4,1071.0,34.7
,22.79,2394,850.0,847.9,4.8,21.48,2310,42.2,35.2,38.0,22.14,2352,1917.6,1387.2,34.7
,24.73,2520,850.0,847.9,4.8,23.44,2436,42.0,35.2,38.0,24.07,2478,1907.4,1407.6,34.7
,26.67,2625,850.0,847.9,4.8,25.37,2562,41.6,35.2,37.8,26.03,2583,1907.4,1417.8,34.7
,28.61,2730,850.0,847.9,4.8,27.31,2667,41.2,35.2,37.6,27.95,2688,1907.4,1417.8,34.7
,30.59,2814,850.0,847.9,4.8,29.28,2751,41.0,35.2,37.4,29.96,2793,1907.4,1428.0,34.7
,32.54,2919,850.0,847.9,4.8,31.24,2856,40.8,35.2,37.2,31.89,2877,1907.4,1417.8,34.7
,34.49,3003,850.0,847.9,4.8,33.20,2940,40.6,35.2,37.0,33.85,2982,1907.4,1417.8,34.7
,36.41,3045,850.0,808.0,4.8,35.14,3024,40.2,35.2,37.0,35.77,3045,1907.4,1417.8,34.7
,38.38,3066,850.0,801.3,4.8,37.06,3066,40.2,35.2,36.2,37.70,3066,1907.4,1264.8,68.1
,40.37,3066,850.0,818.0,4.8,39.06,3066,40.2,35.2,35.8,39.72,3066,1907.4,1254.6,68.1
,42.31,3066,850.0,811.3,4.8,41.02,3066,40.2,35.2,36.0,41.66,3066,1897.2,1254.6,68.1
,44.27,3066,850.0,804.7,4.8,42.97,3066,40.2,35.2,36.0,43.62,3066,1897.2,1254.6,68.1
,46.21,3066,550.0,808.0,4.8,44.93,3066,40.2,35.2,35.8,45.57,3066,1897.2,1254.6,68.1
,48.18,2919,255.0,561.9,4.8,46.86,3024,0.0,35.2,28.6,47.51,2982,1122.0,1111.8,68.1
,50.15,2772,250.0,565.3,4.8,48.85,2877,0.0,35.2,26.6,49.50,2814,1111.8,1091.4,68.1
,52.12,2646,250.0,565.3,4.8,50.82,2730,0.0,35.2,26.8,51.46,2688,1101.6,1081.2,68.1
,54.04,2541,250.0,561.9,4.8,52.75,2604,0.0,35.2,26.6,53.39,2583,1091.4,1081.2,68.1
