Tastverh. Ladedruckregelventil
Mc_Givertechnik
2010 Volkswagen T5
Beitrag04-07-2004, 21:46    Titel: Tastverh. Ladedruckregelventil Antworten mit Zitat
Hallo!
Bei einer Messfahrt mit meinem 2000er ACV konnte ich feststellen, daß das Tastverhältnis des Ladedruckregelventieles weit unter den Sollwerten liegt.
Time U/min soll/mbar ist/mbar Tastverhältnis
,11.14,2264,1479.0,1336.2,12.8,,,,,,,,,,
,11.58,2244,1479.0,1336.2,12.8,,,,,,,,,,
,12.00,2203,1479.0,1326.0,12.8,,,,,,,,,,
,12.43,2224,1672.8,1336.2,12.8,,,,,,,,,,
,12.84,2203,1785.0,1438.2,12.8,,,,,,,,,,
,13.28,2203,1805.4,1560.6,12.8,,,,,,,,,,
,13.70,2224,1876.8,1642.2,12.8,,,,,,,,,,
,14.14,2264,1876.8,1744.2,12.8,,,,,,,,,,
,14.57,2285,1876.8,1805.4,12.8,,,,,,,,,,
,15.01,2305,1734.0,1774.8,17.5,,,,,,,,,,
,15.45,2305,1744.2,1713.6,15.9,,,,,,,,,,
,15.88,2326,1795.2,1703.4,12.8,,,,,,,,,,
,16.32,2326,1795.2,1723.8,12.8,,,,,,,,,,
,16.75,2346,1795.2,1734.0,12.8,,,,,,,,,,
,17.19,2366,1795.2,1734.0,12.8,,,,,,,,,,
,17.61,2387,1805.4,1744.2,12.8,,,,,,,,,,
,18.04,2387,1876.8,1785.0,12.8,,,,,,,,,,
,18.46,2428,1876.8,1846.2,12.8,,,,,,,,,,
,18.89,2468,1887.0,1907.4,14.3,,,,,,,,,,
,19.31,2489,1887.0,1938.0,16.7,,,,,,,,,,
,19.74,2530,1887.0,1989.0,21.9,,,,,,,,,,
,20.17,2591,1887.0,1958.4,26.3,,,,,,,,,,
,20.60,2652,1887.0,1927.8,27.5,,,,,,,,,,
,21.02,2693,1887.0,1917.6,29.1,,,,,,,,,,
,21.45,2754,1887.0,1907.4,29.9,,,,,,,,,,
,21.87,2795,1887.0,1897.2,30.3,,,,,,,,,,
,22.28,2856,1887.0,1907.4,30.3,,,,,,,,,,
,22.71,2897,1897.2,1897.2,30.7,,,,,,,,,,
,23.14,2754,1499.4,1805.4,48.6,,,,,,,,,,
,23.57,2101,1407.6,1479.0,46.2,,,,,,,,,,
,24.00,1530,1315.8,1336.2,47.8,,,,,,,,,,
,24.44,2162,1836.0,1336.2,12.8,,,,,,,,,,
,24.88,2162,1866.6,1591.2,13.1,,,,,,,,,,
,25.30,2183,1866.6,1876.8,14.7,,,,,,,,,,
,25.73,2224,1876.8,1958.4,21.5,,,,,,,,,,
,26.15,2244,1876.8,1968.6,26.7,,,,,,,,,,
,26.59,2264,1876.8,1948.2,29.9,,,,,,,,,,
,27.02,2285,1876.8,1927.8,31.9,,,,,,,,,,
,27.44,2305,1876.8,1907.4,33.9,,,,,,,,,,
,27.88,2346,1876.8,1907.4,35.1,,,,,,,,,,
,28.31,2366,1876.8,1897.2,35.9,,,,,,,,,,
,28.74,2387,1876.8,1887.0,36.3,,,,,,,,,,
,29.16,2407,1876.8,1887.0,37.1,,,,,,,,,,
,29.59,2428,1876.8,1876.8,36.7,,,,,,,,,,
,30.01,2448,1887.0,1876.8,36.3,,,,,,,,,,
,30.44,2468,1887.0,1887.0,36.3,,,,,,,,,,
,30.87,2468,1887.0,1876.8,35.9,,,,,,,,,,
,31.31,2489,1887.0,1887.0,35.9,,,,,,,,,,
,31.74,2509,1887.0,1876.8,35.5,,,,,,,,,,
,32.17,2530,1887.0,1887.0,35.5,,,,,,,,,,
,32.60,2550,1887.0,1887.0,35.5,,,,,,,,,,
,33.03,2550,1887.0,1887.0,35.5,,,,,,,,,,
Ein Maximum von 48,6 bei einem Sollwertmaximum von 90 ist doch etwas wenig.
Nun meine Frage, ist ein zu geringes Tastverhältnis wirklich ein Indiz für ein defektes Ladedruckregelventil?????? Das sch... Ding kostet nämlich satte € 106.- (für mich noch immer 90 Euros)
Bevor ich da aber blind tausche, möchte ich wissen, ob etwas Anderes eventuell dieses Ventiel negativ beeinflussen könnte????
Gruß, Petert
Ps.: Die testfahrt war natürlich länger, aber dieser Ausschnitt ist markant für die ganze Testfahrt
VW T5 GP Multivan Startline CAAC 2,0 CRD 103 KW
DocSnydor
Beitrag05-07-2004, 8:49    Titel: Tastverh. Ladedruckregelventil Antworten mit Zitat
Könnte es vielleicht nicht auch an der Länge der Stange der VTG-Verstellung liegen?
Mc_Givertechnik
2010 Volkswagen T5
Beitrag05-07-2004, 11:36    Titel: Tastverh. Ladedruckregelventil Antworten mit Zitat
ACV hat Wastegate.
DocSnydor
Beitrag05-07-2004, 12:32    Titel: Tastverh. Ladedruckregelventil Antworten mit Zitat
Aber die Wastegate-Betätigung hat doch auch ne Stange die zu lang oder zu kurz eingestellt sein kann...
Karma: +26 / -0   Danke, gefällt mir!
Beitrag05-07-2004, 16:15    Titel: Tastverh. Ladedruckregelventil Antworten mit Zitat
Echt, hat sie ????
Da muss ich gleich mal meinem 1Z an die Waesche.
Ich dachte, die Stange ist fest (von der Laenge) ??
I don't know what the fuck it was.
Mc_Givertechnik
2010 Volkswagen T5
Beitrag05-07-2004, 21:57    Titel: Tastverh. Ladedruckregelventil Antworten mit Zitat
Is schon einstellbar, aber es wurde daran bei mir nichts verändert. Natürlich könnte dies den ewig immer gleich bleibenden Ladedruck erklären, sollte diese Schubstange von Anfang an falsch eingestellt gewesen sein??????????????
Grüße, Peter
Ps.: Möchte an sich grundsätzlich nichts verstellen, was nicht sein muß
Beitrag06-07-2004, 13:09    Titel: Tastverh. Ladedruckregelventil Antworten mit Zitat
Hae ??? Der ist doch nciht immer gleich !
Hohe Tastwerte scheinen den Ladedruck zu senken. Und dass dieser Regelkreislauf funktioniert, sieht man an dem Log.
Also ich sehe anhand der Werte keinen Veraenderungsbedarf.
Mc_Givertechnik
2010 Volkswagen T5
Beitrag06-07-2004, 13:24    Titel: Tastverh. Ladedruckregelventil Antworten mit Zitat
Hi!
Unter gelich bleibenden Ladedruck, habe ich den immer gleichbleibenden maximal Ladedruck gemeint. Mehr als 0,7 Bar konstant sind nicht raus zu holen. Bis 0,92 Bar laut Sollwertetabelle müssten drin sein. Fazit, es fehlt Luft im Vollastbereich, darum rußt er. So stell ich mir das halt vor, ich kann mich aber täuschen. In welche Richtung das Tastverhältnis gehen muß, bei neidrigem oder hohem Ladedruck weiß ich nicht, aber nach dem das Tastverhältnis mit zunehmender Drehzahl steigt, sollte dann bei Vollast und erreichter Drehzahl ein Tastverhältnis von 90 anliegen (Sollwertetabelle). Was aber nicht geschieht. Irrtum nicht ausgeschlossen.
Grüße, Peter
Ps.: LMM neu, Magnetventil noch alt. Testfahrt mit neuem Ventil aus Zeitgründen noch nicht durchgeführt
Klausel
KFZ-Schrauber seit: 09.05.2002
Beitrag06-07-2004, 13:51    Titel: Tastverh. Ladedruckregelventil Antworten mit Zitat
Hallo !
Verstehe so einiges nicht:
Du hast doch beim Zeitpunkt 22.71 ein Ladedrucksoll von 1897.2 und sogar einen identischen Ladedruck-Istwert. icon_question.gif
Kurz nach dem Schalten (Zeitpunkt 26.15) ist sogar ein Überschwinger von 1968.6 drin.
Worüber man nachdenken kann, ist der relativ langsame Druckaufbau
zu Beginn des Logs und nach Schalten (ähnlich wie bei mir im AFN, deshalb interessiert mich auch der Thread so).
Die Tastverhältnis-Werte scheinen in der Tat niedrig (auch ähnlich wie bei mir im AFN), vor allem weil man ja wohl den maximalen Wert von 48% noch ignorieren muss, denn zu diesem Zeitpunkt warst Du ja wohl mitten im Schaltvorgang (also keine Last).
Grüße,
Klaus
Beitrag06-07-2004, 13:55    Titel: Tastverh. Ladedruckregelventil Antworten mit Zitat
Ladeluftstrecke undicht?
VCDS-Shop
Beitrag06-07-2004, 14:11    Titel: Tastverh. Ladedruckregelventil Antworten mit Zitat
http://www.luxus-wg.de/~martin/auto_bilder/LDD_ACV.jpg
So, dass ganze mal Bildlich.
Ich wuerde mal etwas mehr loggen, als nur einen Schaltvorgang.
Mach doch mal nen DZT (vielleicht in verschiedenen Gaengen)
Ungefaehr sowas (hier jetzt halt mit Luftmassen)
http://www.luxus-wg.de/~martin/auto_bilder/dzr_lmm.gif
Mc_Givertechnik
2010 Volkswagen T5
Beitrag06-07-2004, 21:13    Titel: Tastverh. Ladedruckregelventil Antworten mit Zitat
Hallo!
Mein LOG ist ja eben nur ein Ausschnitt, der typisch ist, für den ganzen Verlauf der Testfahrt. Ich habe jetzt das Ventil getauscht und werde am Wochenende wieder eine längere Fahrt unternehmen. Jetzt mal ganz blöd gefragt, wie komme ich zu einem mitgeloggten Diagramm??? Bin ich zu blöd, finde das nicht.
@ Rainer
Eine optische Sichtprüfung hat ergeben, daß die Ladeluftstrecke O.K. ist. Ich werde das ganze nochmal mit Seifenwasser testen. Vieleicht sehe ich dann ja eine Bläschenbildung.
Grüße und ein danke an euch,
Peter
Mc_Givertechnik
2010 Volkswagen T5
Beitrag06-07-2004, 21:18    Titel: Tastverh. Ladedruckregelventil Antworten mit Zitat
@KlauselKFZ-Schrauber Profil anzeigen: Klausel
Ich habe ja eine Ladedruckanzeige eingebaut. Jetzt stellt sich natürlich die Frage, hat die Anzeige jetzt ne Meise oder eventuell der Ladedrucksensor????? Irgeneiner mogelt hier. Aber wer? Wie kann ich das feststellen? Soll ich vielleicht den Ladedrucksensor tauschen??? Wenn der nicht viel kostet schmeiß ich ihn raus. Wäre allerdings die Möglichkeit da, den Sensor unter Laborbedingungen 1,0 Bar auszusetzen und dann über VAG COM zu messen, könnte ich das Ganze natürlich kontrollieren, aber so....
Grüß euch, Peter
Beitrag06-07-2004, 22:44    Titel: Tastverh. Ladedruckregelventil Antworten mit Zitat
Das Diagramm ist mit den ueblichen Hausmitteln gemacht (Open Office oder andere Produkte dieser Art icon_smile.gif
VAG-COM spuckt dazu nur die CSV Dateien aus (die kannst du ja erstellen icon_smile.gif
Klausel
Beitrag06-07-2004, 23:55    Titel: Tastverh. Ladedruckregelventil Antworten mit Zitat
Hallo !
Konnte man ja nicht wissen, dass Du auf einmal über Deine LDA sprichst, nachdem Du geloggte Daten hingestellt hast ... icon_smile.gif
Viel Glück bei der Lecksuche.
Grüße,
Klaus
Mc_Givertechnik
2010 Volkswagen T5
Beitrag07-07-2004, 6:15    Titel: Tastverh. Ladedruckregelventil Antworten mit Zitat
Is klar, die Ladedruckanzeige ist ja nur zur Kontrolle da. Jedoch, wenn die nicht richtig anzeigt, tu ich mir natürlich schwer. Ist eine Anzeige von Razimex, min. -0,5 Bar und max. 1,5 Bar. Eine null815 Anzeige hat normalerweise eine Abweichung von max. 2,5%, das sind dann bei 0,7 Bar max. 0,7175 Bar und min. 0,6825 Bar, also eine Differenz von 0,035 Bar. Sollte bei der Differenz meines Ist- und Sollladedruckes normalerweise keine Rolle spielen, da bewege ich mich ja bei 0,2 Bar unterschied.
Kann es wirklich sein, daß der Ladedrucksensor hinüber ist???
Grüße, Peter
Ps.: Nächster Log kommt dann grafisch aufgearbeitet
Keine neuen Beiträge Ladedruckregelventil Diesel Motorentechnik
Keine neuen Beiträge PWM Signal Ladedruckregelventil AFN Dieselschrauber Bar
Keine neuen Beiträge Tastverhältnis Ladedruckregelventil Diesel Motorentechnik
Keine neuen Beiträge Ladedruckregelventil tickt Dieselschrauber Bar
