Passat 96" tdi afn
josip77
Beitrag15-02-2006, 22:07    Titel: Passat 96" tdi afn Zitieren
hello
I must replace ecu,028 906 021 ck,so i have from golf 3 028 906 021df,can i put this and how i codirem ....car have clima,abs,airbag,manual transmision.....
best regards :
Ross-Tech-Support
Beitrag16-02-2006, 8:22    Titel: Passat 96" tdi afn Zitieren
The new ECU should be MSA15, so the coding is 00002.
Since this is not an english speaking forum,
you may use the original english Ross-Tech forum,
or a forum of your local distributor.
http://autos.groups.yahoo.com/group/VAG-COM/
http://www.ross-tech.com/distributors.html
Keine neuen Beiträge Passat 3B AFN - Kraft "von unten" fehlt (lange Ges Diesel Motorentechnik
Keine neuen Beiträge Passat 3C "höher legen" über aut. Niveauausgl... On-Board-Diagnose (OBD)
Keine neuen Beiträge Passat 3c Kombiinstrument: Tachonadel "schwankt" On-Board-Diagnose (OBD)
