Passat 96" TDI AFN
josip77
Post15-02-2006, 22:07    Subject: Passat 96" TDI AFN Quote
hello
I need to replace my ECU (engine control unit), the part number is 028 906 021 CK. I have a replacement ECU from a Golf 3 with the part number 028 906 021 DF. Can I use this replacement, and if so, how do I program it? My car has air conditioning, ABS, airbags, and a manual transmission.
Best regards:
Ross-Tech-Support
Post16-02-2006, 8:22    Subject: Passat 96" TDI AFN Quote
The new ECU should be MSA15, so the coding is 00002.
Since this is not an English-speaking forum,
You may use the original English Ross-Tech forum.
or a forum of your local distributor.
http://autos.groups.yahoo.com/group/VAG-COM/
http://www.ross-tech.com/distributors.html
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat Engine Codes AVF & EYF - Parts & Info Diesel Engine Technology
No new posts Passat 3B AFN: Lack of Low-End Power (Long) Diesel Engine Technology
No new posts Passat 3C: Raise Ride Height with Auto Leveling On-Board Diagnostics (OBD)
No new posts Passat 3c Wagon: Speedometer "fluctuates" On-Board Diagnostics (OBD)
