T5 128 KW TDI Top Speed
New Topic 🔒 Locked 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
poppel
Karma: +1 / -2   Thank you, like it!
Post30-01-2007, 23:07    Subject: T5 128 KW TDI Top Speed Quote
Hello, unfortunately, I haven't been able to make any progress with the search.
Is there a speed limit (Vmax) for the T5, and if so, how can I change it using VCDS?
Best regards, Poppel.
Ross-Tech-Support
CAN Support
Post31-01-2007, 3:08    Subject: T5 128 KW TDI Top Speed Quote
Yes, there is a limitation. However, it makes absolutely no sense to remove them, and even if you did, it would only make the vehicle slightly faster, but it's simply not designed for that.
poppel
Post01-02-2007, 1:54    Subject: Maximum speed Quote
I would be satisfied just to know how it's done or where to find information about it.
The question wasn't about whether it makes sense; I'm concerned with the technical solution.
I'm officially out of the Need for Speed: Alter community.
It would be great if someone with technical expertise could provide an answer.
Ross-Tech-Support
CAN Support
Post01-02-2007, 1:58    Subject: T5 128 KW TDI Top Speed Quote
You have to ask a chip tuner; there's no other way.
poppel
Post01-02-2007, 2:03    Subject: maximum speed Quote
Okay, let's get started... all chip tuners, please answer.
Kids take over!
Post01-02-2007, 7:40    Subject: T5 128 KW TDI Top Speed Quote
You can ask a farmer for a glass of milk. Maybe he'll even give it to you for free.
But no farmer would be so foolish as to give away his only cow.
No new posts Nicht mehr volle VMAX Diesel Engine Technology
No new posts 2.5TDI V6 150PS, AKN (no top speed limiter) Diesel Engine Technology
