Water Pump: Should You Replace It Now?
charlyfirpo
2013 Volkswagen Golf
Post03-02-2007, 11:34    Subject: Water Pump: Should You Replace It Now? Quote
Hello.
I have a general question about water pumps.
My TDI is approaching 180,000 km (approximately 112,000 miles). Now it's time for another timing belt replacement. Should I replace the water pump at the same time?
Are there any known lifespans or typical durations for these products?
"Well, that sounds like a bit of work. I might as well replace the pump while I'm at it."
Best regards, Charly.
Golf 4 GTI TDI, ARL Serie 346031 Km
Webasto Thermo Top E
15.02.2013 -> Golf 6 GTD DSG CFGB/NLN, TT-V+T91R
21.03.2016 -> Golf 7 R, Limestonegrey, 19", Voll...
Translated on 23-08-2026, 22:29.
Rudi
Post03-02-2007, 14:15    Subject: Water Pump: Should You Replace It Now? Quote
Hi Charly,
Change it out!
There have been cases where the timing belt didn't last its expected lifespan or replacement interval.
survived.
Rudi
Translated on 23-08-2026, 22:30.
charlyfirpo
Post03-02-2007, 14:47    Subject: Water Pump: Should You Replace It Now? Quote
Thank you.
Okay, I will do that.
Translated on 23-08-2026, 22:31.
No new posts Document: Engine starts, then immediately stalls. Model: ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Should the water pump definitely be replaced? Diesel Engine Technology
No new posts 1.9 TDI Timing Belt: Should You Replace the KW Nut? Diesel Engine Technology
No new posts Water pump replacement? Diesel Engine Technology
No new posts ALH TDI Wasserpumpe undicht? Diesel Engine Technology
