Hello, my Super Kangoo diesel 1.9 D 65hp won't start anymore.
The Kangoo has a total mileage of 330,000 km. The engine (brand new) was installed 2 years ago and currently has approximately 10,000 km. However, the fuel injection pump has not been replaced.
Tomorrow, the diagnostic system will be used to read the error codes from the Renault. The fuel injection pump (R8448B171A) does not have an immobilizer. The ADAC (German Automobile Club) has determined that the pump is not delivering any diesel fuel (the timing belt is okay, and the magnetic valve is also working, including the electrical supply).
I have a new pump (part number R8448B232A) with an immobilizer that I have already removed. The magnetic valve is the same. The pump also has two other electronic components: one is a magnetic valve for early ignition, and the other I don't know. Can anyone tell me if the two other electronic components are the same on both pumps?
Thank you for any response.
Sincerely,
D. Lehmann.
Translated on 17-10-2026, 13:11.
