Air Mass Sensor Idle, Engine Code AGR
Malte1408
Post12-02-2007, 14:50    Subject: Air Mass Sensor Idle, Engine Code AGR Quote
Hello everyone,
Currently, I'm preoccupied with the following:
Is an air mass of 480 mg/H at idle, without EGR, normal?
(Engine running at operating temperature)
That seems like a lot to me.
The maximum EGR valve setting of 69%, which is controlled by the engine control unit (ECU) during normal operation, is just enough to reach the already highly adapted air mass value of 380 mg/H.
In the default MWB 3 setting, with a control value of 100%, the air mass is 230 mg/H.
Is my mass airflow sensor icon_eek.gif reading too high, or is my EGR valve sticking or not opening far enough?
Please, if anyone has an AGR (Exhaust Gas Recirculation) valve or a similar device, could you please post the target/actual values and the air mass values (target value 0 / 100%) at idle, as well as the basic settings for MWB 3?
Thank you very much and best regards.
Malte.
Translated on 12-10-2026, 14:31.
BM
Avatar-BM
Post12-02-2007, 21:28    Subject: Air Mass Sensor Idle, Engine Code AGR Quote
Are you looking here: http://www.dieselschrauber.de/Solldaten_Main.html
If you have a lambda sensor (oxygen sensor) from China with German packaging, I would recommend replacing it with one from Bosch as a first step.
3B5 AJM
Translated on 12-10-2026, 14:33.
Malte1408
Post12-02-2007, 21:53    Subject: Air Mass Sensor Idle, Engine Code AGR Quote
BM wrote:
Look here: http://www.dieselschrauber.de/Solldaten_Main.html
If you have installed an LMM from China with German packaging.
The air mass sensor seems to be working fine. I have no idea why it's having trouble with the exhaust, but I'll leave it as it is for now.
No new posts Boost behavior of VAG TDI engines, engine code AHF Technical Articles
No new posts Faulty Load Pressure Control Engine Identifier BRE Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power Loss: Air Mass/Boost/Timing OK? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine mass at idle, VAG-COM value Upload
No new posts AFF Engine Code: Meaning & Identification Diesel Engine Technology
No new posts Engine Code: Find Your Car's Engine Type Diesel Engine Technology
No new posts T5 Engine Jerking: CAAB Code Troubleshooting Diesel Engine Technology
