Brake Pedal Sensor 1Z
TOMTOM19630
Karma: +0 / -1   Thank you, like it!
Post17-02-2007, 17:09    Subject: Brake Pedal Sensor 1Z Quote
Hello and have a wonderful day.
I have a question about the VAG Com 303. I'm getting the error code "Brake pedal monitoring: Implausible signal." This error is annoying because the glow plug indicator keeps flashing. Can anyone offer some advice?
It's an Audi 80 B4 1Z, manufactured in 1995.
Translated on 31-10-2026, 23:27.
Post17-02-2007, 17:25    Subject: Brake Pedal Sensor 1Z Quote
Your first post and a flat six (meaning a failing grade).
Maybe check the switch sometime?
TOMTOM19630
Post18-02-2007, 12:00    Subject: Brake Pedal Sensor 1Z Quote
"Thank you for the six Matthias, but unfortunately, this hasn't resolved my problem yet. So, I've re-examined both switches, cleared the error memory, and after a test drive of 3 kilometers, the glow plug indicator started blinking again. When I read the error codes with VAG COM, it showed the same "brake pedal sensor - implausible signal." Now, the same type of switch is mounted on the clutch pedal. Could that be related? It's a bit difficult to get used to diesel technology when you've only worked on gasoline engines for 20 years."
Best regards, Thomas.
Translated on 31-10-2026, 23:28.
TOMTOM19630
Post18-02-2007, 12:05    Subject: Brake Pedal Sensor 1Z Quote
"By the way, a friend of mine has a Golf TDI with a 1Z engine, and I noticed that his car has significantly more power than my Audi, even though both have 90 horsepower. Okay, the Golf is a bit lighter."
Translated on 31-10-2026, 23:29.
DariusPolo
Post18-02-2007, 12:18    Subject: Brake Pedal Sensor 1Z Quote
...have you already used the search function?
Check brake lights and wiring (if OK, replace the switch for €25 at VW).
Darius.
TOMTOM19630
Post18-02-2007, 12:49    Subject: Brake Pedal Sensor 1Z Quote
Die Suchfunktion hat mich nicht weitergebracht, beide Schalter sind neu, mir ist aber bei dem unteren Schalter aufgefallen, das der kein offen und schließsignal ausgibt, mit einer Diodenprüflampe konnte ich das festellen, da mir das keine Ruhe gelassen hat habe ich den unteren Schalter göffnet, ups der kann meiner Meinung nach nicht öffnen oder schließen, da die beiden Schleifkontakte keine Unterbrechung aufweisen, nun stellt sich die Frage über die Funktion des Schalters? Widacquired?
Translated on 31-10-2026, 23:30.
DariusPolo
Post18-02-2007, 13:22    Subject: Brake Pedal Sensor 1Z Quote
/viewtopic.php?t=8012&highlight=brake light switch
Test and compare with VCDS.
Post18-02-2007, 14:28    Subject: Brake Pedal Sensor 1Z Quote
TOMTOM19630 wrote:
... both switches are new...
Is it correctly configured after the change?
/viewtopic.php?t=807&highlight=bremspedalschalter+einstellung (the search function is really great, isn't it? icon_smile.gif)
Translated on 31-10-2026, 23:31.
Ross-Tech-Support
Post19-02-2007, 18:10    Subject: Brake Pedal Sensor 1Z: Monitoring & Replacement Quote
TOMTOM19630 wrote:
Hello and have a nice day.
Could you please specify which errors you are encountering? Also, I would appreciate it if you could update to a more recent version. This is free for registered customers, and all unregistered users can download a more current version 311 or 409 as shareware. Therefore, there is no reason to use such an old version. Once you have updated, please read the error memory again and post the *entire* contents here, ideally using an auto-scan or at least the "copy/save error" function.
Translated on 31-10-2026, 23:32.
No new posts Brake Pedal Sensor: How to Bypass/Defeat? Diesel Engine Technology
No new posts Dual Brake Pedal Monitoring: Safety Risk? Diesel Engine Technology
