Can Xenon control units be coded with VCDS?
GoraDriver
Post24-02-2007, 9:27    Subject: Can Xenon control units be coded with VCDS? Quote
Hello everyone,
Can the control units for the xenon headlights be coded using VCDS (VAG-COM) on a VW Golf 4?
Or does one absolutely have to go to the friendly [place/person]?
Greetings from Bonn.
charlyfirpo
2013 Volkswagen Golf
Post24-02-2007, 16:51    Subject: Can Xenon control units be coded with VCDS? Quote
Hello.
Yes, you can code the control unit to the vehicle using VCDS.
You can also adjust the settings for the axle sensors. However, you will need to take your car to a workshop to adjust the headlights. Unless you happen to have one of those devices in your garage yourself.
My mechanic really fiddled around with the sensors back then to adjust them. Just make sure the values are correct beforehand. Then it will be done quickly.
Best regards, Charly.
Golf 4 GTI TDI, ARL Serie 346031 Km
Webasto Thermo Top E
15.02.2013 -> Golf 6 GTD DSG CFGB/NLN, TT-V+T91R
21.03.2016 -> Golf 7 R, Limestonegrey, 19", Voll...
No new posts HEX-V2: Login failed Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: Coding Daytime Running Lights - How To Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts EDC15: Updateable Engine Control Unit Software Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts What ready-made hardware is available for VagCom? Diesel Engine Technology
No new posts Bi-turbo in the VW? Is that okay? Diesel Engine Technology
No new posts Can I install a motor control unit from a W210 E290 TD in... On-Board Diagnostics (OBD)
No new posts Boost AFN Turbo Pressure: 22k Ohm Resistor? Diesel Engine Technology
