TDI Intermittent Power Loss: Audi A4 Troubleshooting
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Upload
tbkaudia4
Post25-02-2007, 10:37    Subject: TDI Intermittent Power Loss: Audi A4 Troubleshooting Quote
Hi, everything's clear.
The small leak that was causing the problem was a crack in the sealing gasket between the intake manifold and the intercooler piping.
The crack developed during the test drives and eventually started leaking oil.
Despite this, I have a few questions.
Is the logged engine performance data okay? I had a maximum boost pressure of 2350 millibars, but otherwise the pressure is regulated down to approximately 2000 millibars at full load. Does this seem okay? I would appreciate a final confirmation.
Secondly, shouldn't the significantly lower boost pressure trigger an error – specifically a boost pressure regulation fault? I never received any error messages.
Thank you to all F members.
Best regards, Frank.
Ich kann den Inhalt dieser URL nicht abrufen und übersetzen. Bitte gib mir den Text, den du übersetzt haben möchtest.
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den Bäumen. Ein leichter Wind weht durch das Gras. Es ist ein perfekter Tag für einen Spaziergang."
"I've recently been experiencing occasional power loss during acceleration, particularly noticeable between 2000 and 3000 RPM."
(A4 B5, 110 hp TDI, AFN engine - everything is still original).
The following is happening quite suddenly:
Waste exhaust pressure.
Waste EGR 0%.
Waste air mass.
Waste injection rate.
Waste Throttle (Throttle for waste?)
(recorded using VAG COM)
As far as I can tell, everything happens simultaneously, it lasts for about 1-2 seconds, and then things return to normal. The car runs up to its maximum speed, and there are no error codes.
Das wohl das Gas zurückgeht, ist komisch. war auf einer konst. Acceleration.
Mileage: 170,000 km
Does anyone have any ideas?
Hello.
LOG-01-003-010-008_17-25.xls
 File name:  LOG-01-003-010-008_17-25.xls
 File size:  189.5 KB
 Downloaded:  544 times
 File size:  189.5 KB
 Downloaded:  654 times
 File size:  189.5 KB
 Downloaded:  518 times
LOG-01-003-011-020_250207.xls
 File name:  LOG-01-003-011-020_250207.xls
 File size:  220.5 KB
 Downloaded:  667 times
LOG-01-003-010-011.xls
 Log bei konst Beschleunigung, s. diagramm
 File name:  LOG-01-003-010-011.xls
 File size:  186 KB
 Downloaded:  743 times
Translated on 26-07-2026, 19:01.
No new posts VAG 2.0 TDI: No Oil Pressure in Balance Shaft Module Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ASV Error: 'Engine Speed Sensor G80 - No Signal' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Hard landing - no error entry - troubleshooting? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts G4 AHF (110PS) Ruckeln bei niedriger Drehzahl On-Board Diagnostics (OBD)
No new posts TDI Power Loss: Troubleshooting & Solutions Diesel Engine Technology
This topic is locked, you cannot edit or reply. AJM power loss, not turbo pressure Diesel Engine Technology
No new posts Mazda 626 Diesel: Power Loss & Jerking Diesel Engine Technology
