jorank
Joined: 02/26/2007 Posts: 10 Karma: +0 / -0 Location: SĂŒnzhausen / Bayern
26-02-2007, 16:26 Subject: VW T5 GRA: What does it mean? |
"Hello, I installed the GRA (glow relay assembly) in my VW T5, manufactured in 2005, with a 1.9 TDI engine (AXB-059-964). I then tried to unlock it using the login code 11463. The code was accepted, but the GRA still doesn't work. Instead, I now have an error code 1637 in the engine control unit's memory."
It would be great if someone could help me.
Thank you very much.
Here's the error code from the engine control unit's fault memory.
VAG-COM Version: RKS 504.1-UD
Engine Control Unit Part Number: 038 906 016 N
Component and/or Version: R4 1.9L EDC G0000SG 6209
Software coding: 0000031
Workshop code: WSC 02737.
"One error found:"
18045 - Data bus drive: missing message from the electronic central control unit.
P1637 - 000 - -
Translated on 11-10-2026, 18:28.
26-02-2007, 18:30 Subject: VW T5 GRA: What does it mean? |
Please download the latest VAG-COM 607.3 version to the customer's account  .
Regarding the GRA issue, I'm not really sure what to do other than checking the switch bits in the corresponding measurement block.
Regarding the error code: Did you accidentally mess with the control unit coding?
Translated on 11-10-2026, 18:30.
Profile PM WWW Garage |
jorank
26-02-2007, 20:07 Subject: VW T5 GRA: What does it mean? |
I entered the login code with a -10 encoding.
Translated on 11-10-2026, 18:31.
Ross-Tech-Support Profi-Schrauber
26-02-2007, 22:39 Subject: VW T5 GRA: What does it mean? |
...and please post a complete car scan, then we might be able to see where your problem lies.
27-02-2007, 12:38 Subject: VW T5 GRA: What does it mean? |
jorank wrote: | | I entered the login code in the -10-encoding section. |
Hm, function 10 is "adaptation," and that wouldn't be ideal. How can I enter a login code there?
jorank
27-02-2007, 16:21 Subject: VW T5 GRA: What does it mean? |
Quote: | | I entered the login code in the -10-encoding section. |
I'm sorry, I entered 11. Is that correct?
With the new version, it produced the following output.
VAG-COM Version: RKS 607.3-UD
Kfz Rank GmbH
Control unit part number: 038 906 016 N.
Component and/or version: R4 1.9L EDC G000SG 6209.
"One error found:"
P1637 - 000 - -
Error status data:
RPM: 0 /min
Torque: 106.0 Nm
Speed: 0.0 km/h
Last: 0.0%
Voltage: 12.84 V
Binary value: 00001111
Binary value: 00000000
(no unit): 1.0
Self-test: 0 0 X X X
Translated on 11-10-2026, 18:33.
27-02-2007, 16:25 Subject: VW T5 GRA: What does it mean? |
Please perform a complete vehicle scan, with a particular focus on the body control module (BCM).
Translated on 11-10-2026, 18:35.
jorank
28-02-2007, 20:41 Subject: VW T5 GRA: What does it mean? |
I read in another forum that the GRA (presumably a specific feature or system) can only be retrofitted to certain vehicle control units, and apparently, these control units are only...
For vehicles equipped with electric window lifters.
Can you confirm that?[/b]
Translated on 11-10-2026, 18:36.
28-02-2007, 23:51 Subject: VW T5 GRA: What does it mean? |
jorank wrote: | I read in another forum that the GRA (Gearbox Retrofit Adapter) can only be retrofitted to certain vehicle control units, and apparently, these control units are only...
for vehicles equipped with electric window lifters. [/b] |
It has nothing to do with eFH, but if you would just post the results of the auto-scan, as I've asked you to do multiple times, you would have a concrete answer by now.
Translated on 11-10-2026, 18:37.
jorank
01-03-2007, 8:08 Subject: VW T5 GRA: What does it mean? |
hello
I did a quick car scan today.
Kfz Rank GmbH
Thursday, March 1, 2007, 08:20:36.
Vehicle type: 7H - VW Transporter T5.
Scan: 01 02 03 08 09 0D 15 16 17 18 19 1C 22 2D 37 45 46 47 56 57
6E 76 77 78 7D
Chassis number: WV1ZZZ7HZ5H032254
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um drauĂen zu sein."
Address 01: Engine.
Part number SW: 038 906 016 N, hardware number: 028 101 185 5.
Component: R4 1.9L EDC G000SG 6209
Encoding: 0000031
"One error found:"
P1637 - 000 - -
Error status data:
RPM: 0 /min
Torque: 106.0 Nm
Speed: 0.0 km/h
Last: 0.0%
Voltage: 12.84 V
(no unit): 1.0
Address 03: ABS Brakes.
Part number: 7H0 907 379 G
Component: ASR FRONT MK25 0103
Encoding: 0007205
No errors found.
Address 09: Body Control Module.
Part number: 7H0 937 049 J
Component: BORDNETZ SGVER 1.0 0901
Encoding: 0000037
"One error found:"
01598 - Voltage of traction battery.
002 - lower limit exceeded.
Address 15: Airbag.
Part number: 1C0 909 605 A
Component: 3B AIRBAG VW51 0008
Encoding: 13122
Workshop code: WSC 02756.
No errors found.
Address 17: Combination instrument.
Part number: 7H0 920 850 R
Component: KOMBI+WEGFAHRSP VDO V03
Encoding: 01111
Workshop code: WSC 61514.
WV1ZZZ7HZ5H032254 VWZ7Z0D0648667
No errors found.
Address 19: CAN Gateway.
Part number: 6N0 909 901.
Component: Gateway K<->CAN 0001
Encoding: 00006
No errors found.
Address 56: Radio.
Part number: 6X0 035 153 A
Component: Radio BNO 0007
Encoding: 00001
No errors found.
End.
Translated on 11-10-2026, 18:44.
01-03-2007, 8:30 Subject: VW T5 GRA: What does it mean? |
It definitely seems like your vehicle's body control module is incompatible, which means you probably need a new one.
Translated on 11-10-2026, 18:51.
jorank
01-03-2007, 12:37 Subject: VW T5 GRA: What does it mean? |
That would be terrible. Is it possible to simply replace the control unit like that?
jorank
01-03-2007, 17:17 Subject: VW T5 GRA: What does it mean? |
hello
Today I installed a GRA (Gearbox Retrofit Adapter) in a Multivan Startline (R5 2.5 TDI), using the 11463 unlocking code, and it's working. However, the ESP (Electronic Stability Program) light is now on, and I have the following error in the ABS control unit.
Part number SW: 7H0 907 379 R, HW: 7H0 907 379 R.
Component: ESP MK25E1 0104
Encoding: 0000555
3 errors found:
00778 - Steering angle sensor (G85)
003 - Mechanical fault - Intermittent.
Error status data:
Error status: 00100011
Error priority: 2
Error frequency: 1.
Reset counter: 40.
Mileage: 867 km
Time: 0.
Error status data:
Quantity: 0
Quantity: 8193
Quantity: 288
Quantity: 247
014 - defective - intermittent.
Error status data:
Error status: 00101110
Error priority: 2
Error frequency: 1.
Reset counter: 40.
Mileage: 867 km
Time: 0.
Error status data:
Quantity: 256
Quantity: 8449
Quantity: 292
Quantity: 247
005 - No or incorrect initial setup/adjustment.
Error status data:
Error status: 01100101
Error priority: 2
Error frequency: 5
Reset counter: 40.
Mileage: 867 km
Time: 0.
Error status data:
Quantity: 256
Quantity: 8449
Quantity: 8215
Quantity: 249
What now?
Translated on 11-10-2026, 18:54.
01-03-2007, 19:32 Subject: VW T5 GRA: What does it mean? |
Quote: | | 003 - mechanical failure - sporadic |
Either broken...
Quote: | | 005 - No or incorrect initial setting/adaptation |
or that not being done
Translated on 11-10-2026, 18:59.
poppel Blaumann
02-03-2007, 22:10 Subject: GRA and Window Lifters: Repair & Replacement |
There's something to it; the control units that come standard with the power window option don't cause any problems when retrofitting the GRA (presumably a specific system).
jorank
05-03-2007, 8:35 Subject: VW T5 GRA: What does it mean? |
Quote: | | There's something to it; the control units that are installed in the model with power windows don't cause any problems when retrofitting with GRA. |
Is it still possible to reactivate my gray (mobile phone) plan? Would it be worth it if I visit the service provider? Or should I just save my money?
Translated on 11-10-2026, 19:00.
