TDI V6 Timing: AKN Engine Specs & Guide
vikinger
Post07-01-2003, 23:03    Subject: TDI V6 Timing: AKN Engine Specs & Guide Quote
'I'm a complete beginner when it comes to VAG and TDI engines. I bought an A4 2.5 with minor accident damage, BUT... unfortunately, one of the camshaft gears broke due to the accident. I was told that the car was bumped in a parking lot and the engine wasn't running... otherwise, I wouldn't have bought the car! However, while disassembling it, I noticed that someone must have tried to start the engine at some point, as there are marks on the timing belt near the crankshaft sprocket.'
My question: Does anyone know of similar cases with this motor and its output? What kind of damage should I expect?
I couldn't find the adjustment points for setting the valve timing in the manuals. Does anyone have the data they could email me?
Thank you in advance for your help.
Eagle.
Translated on 18-10-2026, 18:37.
No new posts Power Loss: Air Mass/Boost/Timing OK? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Adjusting timing and PD element for common rail diesel en... Troubleshooting & Guides
No new posts 2.0 CR TDI Timing Belts... Volkswagen Timing Belts in gen... Diesel Engine Technology
No new posts AKN Timing: Schedules & Information Diesel Engine Technology
No new posts Tax Deadlines: Important Dates & Info Diesel Engine Technology
This topic is locked, you cannot edit or reply. Adjusting valve timing 1.9 TDI PD AXR Diesel Engine Technology
