AFN Kaltstartprobleme | Posts 16+
Go to page: Previous  1, 2
Post05-04-2007, 15:11    Subject: Quote
It slightly shifts despite the tight coilover spring perch!
If the belt drive is in good condition, then the pump is clearly the cause. I suspect that the injection timing adjustment is simply designed in a way that it can jam. This wouldn't be surprising given the mileage.
A new pump might not be worth it considering the mileage. With a bit of courage and some DIY experience, you might be able to disassemble the part yourself, as described in some technical articles.
Translated on 27-09-2026, 19:34.
myfisch
Post10-04-2007, 21:16    Subject: Quote
Also, here's the translation:
'Also, adjust the fuel injection pump!'
You could try it with a used one! I wouldn't consider swapping it until after I've refilled it with a funnel to completely rule out any air issues! icon_biggrin.gif
@reusselkopp: The coolant temperature sensor is located at the front, under the pump, in the engine block for all 1Z/AHU/AFN engines!
Best, Tom.
Translated on 27-09-2026, 19:35.
Boro
Post11-04-2007, 7:12    Subject: Quote
Sure!
It seems to be the fuel injector adjuster. While the actuator diagnosis is running, the N108 valve can be heard adjusting in idle, and the duty cycle in measuring block 4 changes nicely from 4.8 to 94.4%! However, when viewed with VAG-Scope, the values only move between approximately 80-200! Shouldn't they be 'normally' between 0-255?! Therefore, the piston of the fuel injector adjuster is stuck.
Currently, it is unfortunately impossible to find a used, inexpensive pump... icon_rolleyes.gif
Translated on 27-09-2026, 19:36.
No new posts A6 AAT cold start problems, the umpteenth... Diesel Engine Technology
No new posts T4 2.5 TDI ACV: Cold Start Problems Upload
No new posts Cold start problems 1Z Diesel Engine Technology
No new posts Cold start problems with BLS 1.9 TDI engine Diesel Engine Technology
