Is it possible for a power box to distort the power consumption display?
SeatLeon
Post13-01-2003, 22:03    Subject: Is it possible for a power box to distort the power consumption display? Quote
Does a power box or '10 Cent Tuning' affect the fuel consumption reading (on-board computer), or does it remain unchanged?
edward
Post13-01-2003, 23:17    Subject: Is it possible for a power box to distort the power consumption display? Quote
It is being distorted...
See also:
http://www.dieselschrauber.de/10cent.html
'Side effects', last sentence...
SeatLeon
Post13-01-2003, 23:30    Subject: Is it possible for a power box to distort the power consumption display? Quote
I just reread it. In what dimensions does the distortion occur? Is it just 0.2 to 0.3, or significantly more? Or can it be said that when the power output is increased by 20%, the amount of fuel injected also increases by 20%?
edward
Post13-01-2003, 23:35    Subject: Is it possible for a power box to distort the power consumption display? Quote
I don't believe that an increase in performance of, for example, 20% would necessarily result in an increase in consumption of 20%. I consider the values you mentioned (0,...) to be more likely.
Unfortunately, I don't have a power consumption meter myself, so I can't say with 100% certainty...
Post14-01-2003, 16:29    Subject: Is it possible for a power box to distort the power consumption display? Quote
SeatLeon wrote:
I just reread this. In which dimensions does the distortion occur? Is it only 0.2 to 0.3, or significantly more? Or can it be said that when the power output is set to 20% higher, 20% more fuel is also injected?
Hi.
In the upper performance range, the increased fuel consumption is even higher than the increased fuel quantity, because very long injection times reduce the engine's efficiency.
Generally, the actual fuel consumption will increase to the extent that more diesel fuel is injected than intended by the EDC (Electronic Diesel Control).
Since the onboard computer calculates based on the intended amounts and doesn't detect the deviation, the MFA (Multifunction Display) also indicates a quantity that is too low by the same amount.
No new posts Tuning comparison: Chip vs. Powerbox Technical Articles
No new posts A4 8E2/8E5 - Possible various error memory messages Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Is it possible to install a G40 engine without replacing ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Are radio influences on ECUs possible? On-Board Diagnostics (OBD)
No new posts Usage Display PD On-Board Diagnostics (OBD)
No new posts MFA Error: Report a Problem Now! Diesel Engine Technology
No new posts Adjust Consumption Display Diesel Engine Technology
