The marked screw and all the other screws located around it at the same height need to be removed. Not only the M5 (size bleed screws, but all the threaded connections must be removed.
CAV High-Pressure Pump Component
File size:
431.85 KB
Viewed:
1376 times
File size:
4.2 KB
Viewed:
1588 times
Wer Rechtschreibfehler findet, kann sie behalten !
