Hose Patterns: Find Your Perfect Fit!
Post02-01-2003, 15:58    Subject: Hose Patterns: Find Your Perfect Fit! Quote
Hello everyone.
If, for example, the turbocharger boost pressure is incorrect, the control hoses are often suspected – and yet frequently overlooked, as the magnetic valve is often replaced first.
Is there any interest in schematic diagrams of the hose routing for the 1Z / AHU or AFN engines, along with brief descriptions of common failure patterns?
"Can symptoms Y and Z occur if hose X is leaking?"
If so, I could put together something as a "white-noise-how-many-th" type of article – provided that Rainer still has space on the servers icon_rolleyes.gif.
Translated on 29-07-2026, 0:22.
edward
Post02-01-2003, 18:13    Subject: Hose Patterns: Find Your Perfect Fit! Quote
Hi Ulf!
As a driver of a 1Z vehicle, I can only ask you to put your offer into action...
It would certainly be a valuable addition, and it wouldn't come cheap.
Translated on 29-07-2026, 0:24.
Stefan .
Post02-01-2003, 20:02    Subject: Best German Coffee: Buy Online & Enjoy! Quote
Possibly, I could contribute a plan for the AFB (Air Force Base).
icon_wink.gif Stefan.
joergs
Post02-01-2003, 23:28    Subject: Hose Patterns: Find Your Perfect Fit! Quote
@ulf
Great interest! / High level of interest!
Translated on 29-07-2026, 0:25.
Post05-01-2003, 16:28    Subject: Hose Patterns: Find Your Perfect Fit! Quote
Hello.
Since Rainer apparently still has some space on the servers, I'll put something together soon.
edward
Post07-01-2003, 15:20    Subject: Hose Patterns: Find Your Perfect Fit! Quote
@Ulf:
Thank you for your effort...
Post07-01-2003, 17:34    Subject: Wastegate Solenoid Connections: How To Connect? Quote
Hello to all 1Z, AHU, and other wastegate owners.
I need the hose connection designations on the turbocharger control solenoid valve for the wastegate system plan.
For the AGR valve, the labels should be VAC, ATM, and OUT... Can anyone tell me what the corresponding labels should be for the other valve?
Or are the connections at the end not labeled icon_question.gif?
Translated on 29-07-2026, 0:26.
Post16-01-2003, 16:35    Subject: SEO-Optimized German to English Translations Quote
Hello.
Unfortunately, I couldn't find any information about the 1Z solenoid valve.
Therefore, the article about the hose incident is now "live" online.
Translated on 29-07-2026, 0:27.
Määtes
Post16-01-2003, 17:16    Subject: Hose Patterns: Find Your Perfect Fit! Quote
At this point, I'd like to extend a big thank you to Ulf for the excellent explanation!
Of course, also to Rainer and to everyone else who actively supports us here.
Great forum, keep it up icon_razz.gif icon_razz.gif icon_razz.gif.
Sure, here's the translation:
'Hey guys!'
Translated on 29-07-2026, 0:28.
haehnlein
Post16-01-2003, 19:38    Subject: Wastegate Valve Connections: How To Connect Them Quote
ulf wrote:
I need the hose connection designations on the boost pressure solenoid valve for the wastegate charger plan.
Hi Ulf,
"There's nothing printed on my solenoid valve! The connections are correct according to the technical article (I have the repair manual)."
Best regards, Christian.
Translated on 29-07-2026, 0:29.
Post16-01-2003, 21:00    Subject: Wastegate Valve Connections: How To Connect Them Quote
haehnlein wrote:
There's nothing on the solenoid valve for me! The connections are correct according to the technical article, but
Hi Christian,
Ah, so the wastegate image is actually complete icon_smile.gif.
I had obtained the external design from several documents.
Translated on 29-07-2026, 0:30.
