pa-mm6 Blaumann
24-06-2007, 17:06 Subject: Golf TDI: When was the emissions light installed? |
"Hi, but in which production year was the emissions warning light installed in the Golf 4 TDI? I have a Golf 4 TDI 150 hp with engine code ARL and 4Motion, manufactured in 02/02, and the warning light doesn't illuminate when I turn on the ignition. However, a friend with an ASZ engine, manufactured in 06/03, has the light coming on."
"This issue also doesn't appear during the actuator test (engine control unit) on my car, but it does on my friend's car, which then displays the message 'Engine fault, workshop required'."
I'm really curious why this isn't lighting up for me.
"MFG" is an abbreviation for "mit freundlichen Grüßen," which means "best regards" or "sincerely." It is commonly used in German-language emails and letters. Audi SQ5 8R Cvub
Translated on 18-10-2026, 3:21.
Profile PM Email |
24-06-2007, 19:23 Subject: Golf TDI: When was the emissions light installed? |
Keyword: Introduction to EOBD.
Translated on 18-10-2026, 3:22.
pa-mm6 Blaumann
24-06-2007, 20:17 Subject: Golf TDI: When was the emissions light installed? |
Hi.
"That's strange, it should have already been available from the 2002 model year. However, I can't read any reasonable values using VAG-COM on either vehicle via OBD. Is this only related to the engine control unit, or are there other factors involved? Both vehicles have the Euro 3 emissions standard."
Profile PM Email |
24-06-2007, 20:22 Subject: Golf TDI: When was the emissions light installed? |
pa-mm6 wrote: | | ...it's strange, it should have already been available on the model 02. |
Not with diesel.
http://obd-2.de/techn.html
pa-mm6 wrote: | | However, even with VAG Com, I can't read any reasonable values via OBD on the new model. Is this only related to the control unit? Or are there other factors involved? |
What do you understand by "reasonable values"?
Translated on 18-10-2026, 3:23.
pa-mm6 Blaumann
26-06-2007, 20:08 Subject: Golf TDI: When was the emissions light installed? |
HI.
It's not showing up under "Exhaust Gas Recirculation" (EGR) in VAG Com 7... and otherwise, nothing useful appears in the OBD measurement block.
Translated on 18-10-2026, 3:24.
Profile PM Email |
26-06-2007, 23:42 Subject: Golf TDI: When was the emissions light installed? |
If the control unit doesn't provide the data, the VC (Vehicle Computer) can't display anything either. Today, I also had a 2006 A6 that did NOT support OBD-2/EOBD.
