Fuel Pump or Injector: Which is Best?
tim27
Post21-01-2003, 22:06    Subject: Fuel Pump or Injector: Which is Best? Quote
Wouldn't it be better to achieve a higher performance increase with a larger pump instead of with larger injectors? Because if you install a pump from an 81 kW TDI engine into a 66 kW TDI engine, the engine will receive more diesel with the same injection profile, even with the same injectors. However, the injection duration shouldn't be longer, as the larger pump would have to compensate for the increased amount of fuel with a higher injection pressure. Additionally, the engine should run cleaner in this scenario.
That would also be a safer method than installing larger nozzles, as you wouldn't know for sure if they would still be compatible with the engine (in terms of combustion).
Translated on 10-10-2026, 19:43.
No new posts P261A, P261B - Pump for coolant Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replacing injector nozzles in common rail injectors Troubleshooting & Guides
No new posts Golf 1J Headlight Washer Pump Leak - Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Replace Single Diesel Injector? Diesel Engine Technology
No new posts Injector Lifespan: VW TDI 115PS Engine Durability Diesel Engine Technology
No new posts T4/A6 Injectors: Which is Best? Diesel Engine Technology
No new posts AHF Nozzles: 0.232mm vs 0.216mm for Chips Diesel Engine Technology
