luebby1 Guest
09-07-2007, 12:37 Subject: A3 8P SWRA Coding: How-To Guide |
I retrofitted the SWRA system to my A3 and now I need to program the onboard computer.
Okay, so here's my problem: I'm having trouble with the coding.
I have this encoding.
A5885E0082141000000000000000000000
How do I need to modify it so that it is encoded as SWRA? (Specifically, which bits need to be changed to what values?) Because I'm not very familiar with manipulating individual bits like that (e.g., changing byte 01, bit 00).
Translated on 23-09-2026, 1:12.
09-07-2007, 12:47 Subject: A3 8P SWRA Coding: How-To Guide |
If you're already quoting foreign languages here (hinting at encoding), then tell us what the part number of the engine control unit is.
m; Transparency, Teamwork
Translated on 23-09-2026, 1:13.
Profile PM Garage |
09-07-2007, 12:49 Subject: A3 8P SWRA Coding: How-To Guide |
For the 8P0-907-279 part, the SWRA is located at byte 1, bit 1.
Bit 0 relates to "seat occupancy detection".
Translated on 23-09-2026, 1:14.
Profile PM Garage |
vagtuning Guest
09-07-2007, 13:02 Subject: A3 8P SWRA Coding: How-To Guide |
Please provide the text you would like me to translate from German to English. I will only provide the translation, without any explanations.
A58A5E0082141000000000000000000000
luebby1 Guest
09-07-2007, 16:32 Subject: A3 8P SWRA Coding: How-To Guide |
Yes, thank you, it's working now.
You're welcome.
Translated on 23-09-2026, 1:15.
