Never Ending Story? VAGCOM-Adapter | Posts 16+
Go to page: Previous  1, 2
Post23-01-2003, 16:47    Subject: Quote
BERT wrote:
I have a tool that allows you to address RTS (L-line) and TXD (K-line) connections both statically and dynamically.
If there is interest, I could email that document to a central point of contact.
Hi Bert.
I would also be very interested in that.
If the licensing allows it, I would pass it on to Rainer, in case he can/wants to make it available for download. Then you would save yourself a lot of emails with the same content.
Translated on 25-07-2026, 19:43.
Post23-01-2003, 19:14    Subject: Quote
ulf wrote:
BERT wrote:
Hi there,
Hi Bert.
If it is possible from a licensing perspective, I would pass it on to Rainer, in case he can/wants to make it available for download. Then you would save yourself many emails with the same content.
Don't forget this problem: /viewtopic.php?p=10101&highlight=#10101
If there are any problems with the license, I can (if I have time) create a small program myself to handle it.
Windows provides the following API functions for this purpose:
Code:
The EscapeCommFunction function directs a specified communications device to perform an extended function.
BOOL EscapeCommFunction(
  HANDLE hFile,  // handle to communications device
  DWORD dwFunc   // extended function to perform
Parameters
hFile
Handle to the communications device. The CreateFile function returns this handle.
dwFunc
Specifies the code of the extended function to perform. This parameter can be one of the following values: Value Meaning
CLRDTR Clears the DTR (data-terminal-ready) signal.
CLRRTS Clears the RTS (request-to-send) signal.
SETDTR Sends the DTR (data-terminal-ready) signal.
SETRTS Sends the RTS (request-to-send) signal.
SETXOFF Causes transmission to act as if an XOFF character has been received.
SETXON Causes transmission to act as if an XON character has been received.
SETBREAK Suspends character transmission and places the transmission line in a break state until the ClearCommBreak function is called (or EscapeCommFunction is called with the CLRBREAK extended function code). The SETBREAK extended function code is identical to the SetCommBreak function. Note that this extended function does not flush data that has not been transmitted.
CLRBREAK Restores character transmission and places the transmission line in a nonbreak state. The CLRBREAK extended function code is identical to the ClearCommBreak function.
Return Values
If the function succeeds, the return value is nonzero.
If the function fails, the return value is zero. To get extended error information, call GetLastError.
  und
The SetCommBreak function suspends character transmission for a specified communications device and places the transmission line in a break state until the ClearCommBreak function is called.
BOOL SetCommBreak(
  HANDLE hFile   // handle to communications device
Parameters
hFile
Return Values
Translated on 25-07-2026, 19:45.
Post23-01-2003, 20:29    Subject: Quote
Rainer K. wrote:
But don't forget this problem: /viewtopic.php?p=10101&highlight=#10101
Hi Rainer,
It's already clear, but with controlled impulses, one could at least measure the delay of the positive and negative flanks between TXD, K-line, and RXD using only an oscilloscope, and then optimize it under real conditions using a potentiometer – i.e., by connecting the adapter to a diagnostic PC.
That would be a step in the right direction.
Translated on 25-07-2026, 19:47.
BERT
Post24-01-2003, 9:14    Subject: Quote
Hi there.
License issue:
The program is custom-made. It uses a DLL from B. Kainka, which can be downloaded from the internet, to avoid having to deal with the API directly.
(The DLL uses the API and is compatible with NT, 2000, and should also work with XP.)
The program was initially created to test the execution times, including the influence of the computer system.
I will send it to Rainer. He can then distribute it for testing.
Okay, then.
Translated on 25-07-2026, 19:49.
No new posts Dimensions GT17/BV43 Turbocharger Adapter Technical Data
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts VAGCOM Minimal Adapter Diesel Engine Technology
No new posts VAGCOM Adapter: The Essential Guide Diesel Engine Technology
No new posts Another VAGCOM adapter Diesel Engine Technology
No new posts VAGCOM Adapter: Power Consumption & Requirements Diesel Engine Technology
