Newer ESP generation console, but from the old block
ernie_cb
Post05-04-2006, 12:41    Subject: Newer ESP generation console, but from the old block Quote
As described in this article, it is possible to install newer ESP pumps by replacing the mounting bracket.
t=2649&start=0&postdays=0&postorder=asc&highlight=esp%20ahh%20console
You only need to...
New console from AHH 028 130 147 M.
Pulley, new, part number 028 130 107D.
and the ESP.
'Now, it's hard to find a used AHH engine, so I'm wondering if there are other engine codes that have the newer generation of fuel injection pumps, and whether there's an old block or a bracket that fits the old blocks.'
Okay, here's the translation:
'This weekend, I replaced my water pump, and in the process, I had to remove the bracket that holds the alternator (LIMA) and the air conditioning unit. Now, the ESP (Electronic Stability Program) on the AFN engine has a single bracket for both of these components!'
At ASV and similar organizations (which have the PD block), the idea is to have only one mounting bracket for everything. Is that correct?
Has anyone already done this conversion? I can't get the person who wrote about it to respond! I need to see the photos that show the modifications I still need to make!
It would be great if someone could help me! If anyone has a similar holder, please offer it up. I would appreciate any tips and photos.
Best, Björn.
t3_tdi
Post25-07-2007, 13:41    Subject: Newer ESP generation console, but from the old block Quote
Has a solution been found for your question? I'm actually experiencing the same problem...
Best regards, Gunnar.
ernie_cb
Post27-07-2007, 8:34    Subject: AHH Console Quote
Hi, I couldn't find any other consoles!
As a tip, check out some major online retailers!
Best regards, Björn.
This topic is locked, you cannot edit or reply. Towing Hitch Unlock: VW Golf 5 and Newer Models Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Does the ESP control unit from the ALH engine fit the 1Z ... Diesel Engine Technology
No new posts VW TDI Turbo Whistles: Troubleshooting Guide Diesel Engine Technology
No new posts Diagnostic plug for old 1Z engine Diesel Engine Technology
No new posts Adaptation channels for older R5 TDI engines On-Board Diagnostics (OBD)
