Engine Revs Briefly on Its Own?
zecke24
Post26-09-2007, 22:13    Subject: Engine Revs Briefly on Its Own? Quote
'I mentioned this problem here some time ago, but unfortunately, the previous posts didn't offer any helpful solutions. I have a Passat TDI with a 130 hp AVF engine.'
Occasionally, the car accelerates on its own while driving. It's only for a very short time, causing the car to briefly accelerate sharply and lurch forward (maybe for about 1 second).
das macht er auch wenn ich mich rollen lasse oder bremse, also bei Schubabschaltung. Ich habe festgestellt, daß dies nur bei bestimmten Drehzahlbereichen (ungefähr lt. Drehzahlmesser) passiert: bei 1600, 2000, 2600 und 3200 U/min. Aber nicht immer. Die Verbrauchsanzeige zeigt in diesem Moment auch einen Verbrauch an so zwischen 0,5 - 1,1 l/100km, wohlgemerkt bei Schubabschaltung, wo ja eigentlich kein Sprit befördert werden dürfte. Der Fehlerspeiche sagt nichts. Hhelp!!!
Best regards, Arne.
Translated on 25-08-2026, 6:52.
Malte1408
Post26-09-2007, 23:39    Subject: Engine Revs Briefly on Its Own? Quote
Okay, I just skimmed the old thread. As you mentioned, you've already replaced the coolant temperature sensor.
I'm afraid this error will only be resolved with a lot of research effort.
Several sources could be causing the error, so the only solution is to log data and hope that an outlier will appear long enough to identify it.
Can you somehow trigger the error?
Translated on 25-08-2026, 6:53.
scrdel
Karma: +4 / -2   Thank you, like it!
2002 Volkswagen Passat
Post27-09-2007, 18:35    Subject: Engine Revs Briefly on Its Own? Quote
"... that sounds so much like the G62 that, if I were you, I would exchange it again..."
It's possible that a new part could be defective, or perhaps there's an issue with the wiring to the G62.
It's better to waste 25 euros than spend forever searching for something.
Sven.
Passat Variant Highline 2,0 TDI 103KW
Translated on 25-08-2026, 6:54.
zecke24
Post27-09-2007, 22:40    Subject: Engine Revs Briefly on Its Own? Quote
I can't reproduce the error on demand. It only occurs when I drive for a long time within the specified RPM ranges. I only have a trial version of VAGcom, and unfortunately, I don't have a laptop to log data while driving. What else can I do?
Best regards, Arne.
Translated on 25-08-2026, 6:55.
makrospex
Post02-10-2007, 17:52    Subject: Engine Revs Briefly on Its Own? Quote
It's possible that the ESP isn't fully recalibrating...
The consumption display also receives its data from the energy management system (EMS)/control unit.
Possibly the point machine is dirty or slightly misaligned.
It's just a guess; I had the same problem with my old Passat sometimes, but it was sold before I could find the cause.
macro
Opel Vivaro Kombi, 2.0 CDTI 110kW BlueHDI (MKB: AH01), BJ 2020
Translated on 25-08-2026, 6:56.
Hati
Post02-10-2007, 18:01    Subject: Engine Revs Briefly on Its Own? Quote
Even if the G62 were defective, it should under no circumstances inject fuel at speeds far above idle and without the accelerator pedal being pressed. My suspicion leans more towards a faulty throttle potentiometer or wiring.
Translated on 25-08-2026, 6:57.
makrospex
Post02-10-2007, 18:09    Subject: Engine Revs Briefly on Its Own? Quote
...which can also be observed using a VAG-COM device or a multimeter.
However, I would choose an analog multimeter in that case, if a VAG-COM diagnostic tool is not available.
macro
Translated on 25-08-2026, 6:58.
Malte1408
Post02-10-2007, 20:15    Subject: Engine Revs Briefly on Its Own? Translating...
[Translating...]
Könnte sein, dass die ESP nicht ganz zurückregelt...
Die Verbrauchsanzeige bezieht ihre Daten ja auch von der ESP/Regelung.
Evtl. ist das Mengenstellwerk verdreckt oder leicht verstellt.
Er hat keine ESP und auch kein Mengenstellwerk...
Regeldifferenzen vom MSW die so grob sind, daß das Fahrzeug von alleine beschleunigt gäben mit ziemlicher Sicherheit einen Fehlereintrag.
Was das Mengenstellwerk angeht ist die EDC ziemlich penibel. Schau Dir die Tolenranzen vom Vollast-/ Stopanschlag in MWB 19 an...
No new posts Engine temporarily maintains RPM, automatically increases... General Tips
No new posts Passat gibt Schläge - ESP Leuchte geht an Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AJM Motor - Motor klappert, Leistungsmangel, Schwarzrauch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine stalls shortly before reaching operating temperature On-Board Diagnostics (OBD)
No new posts Motor PD TDI 1,9 AVF "gibt alleine Gas" Diesel Engine Technology
No new posts Einspritzpumpenförderbeginn verändert sich selbstständig Diesel Engine Technology
No new posts Does the Sharan brake automatically? Is the ESP system re... On-Board Diagnostics (OBD)
