7-Digit PIN Failure: Common Causes & Solutions
tdi-seppl
Post01-02-2003, 16:33    Subject: 7-Digit PIN Failure: Common Causes & Solutions Quote
"Since I wanted to replace my instrument cluster, I contacted several dealers to obtain the necessary codes. Unfortunately, not a single dealer was willing to generate a 7-digit PIN, provide the WSC (Vehicle Identification Number), or give me the importer number. I had to listen to all sorts of things, from 'a replacement is not possible' to 'you have to come in person, they can't do it remotely. Please bring your ID and vehicle registration as proof of ownership!'"
Can someone here possibly help me and provide or obtain the data I need?
Translated on 24-10-2026, 1:51.
Cord
Post02-02-2003, 5:15    Subject: 7-Pin Connector: A Failed Design? Quote
Good evening.
VW workshops are actually not allowed to give you the code.
Do you perhaps know anyone who works at Volkswagen?
Translated on 24-10-2026, 1:52.
Wolfgang, syncro16
Post05-02-2003, 18:03    Subject: 7-Digit PIN Failure: Common Causes & Solutions Quote
I also had to show my ID and the vehicle registration document, because the workshop is responsible if you mess something up with the vehicle identification number.
Hello.
Wolfgang.
Varianti
Post07-02-2003, 7:23    Subject: 7-Digit PIN Failure: Common Causes & Solutions Quote
And always remember, the code is only valid for 24 hours!
Translated on 24-10-2026, 1:53.
Cord
Post07-02-2003, 15:49    Subject: 7-Digit PIN Failure: Common Causes & Solutions Quote
Not with VAG-COM.
You can still use the code two years later. You just need to know the date it was generated.
