Measurement Data: Complete Removal?
Post21-02-2008, 10:30    Subject: Measurement Data: Complete Removal? Quote
Hi.
Can VAGCOM do that?
So, should I simply query all relevant data points and record them along with their units?
Code:
Messwerteblöcke normiert
1         0  U/min            0.0  mg/h           0.00  KW            39.6  °C
2         0  U/min            0.0  %              _0_0 1__0           39.6  °C
3         0  U/min            640  mg/H           0  mg/H             101  %
4         0  U/min            5.0  °v.OT          0.00  KW            0.00  KW
5         0  U/min            0.0  mg/h           2                   39.6  °C
6         0  km/h             0000 1000           0.0  %              0000 0000
7         25.2  °C                                23.4  °C            39.6  °C
8         0  U/min            93  Nm              0  Nm               139  Nm
9         0  U/min            -1280.0  Nm         500  Nm             0  Nm
10        0  mg/H             989  mbar           989  mbar           0.0  %
11        0  U/min            194  mbar           989  mbar           5  %
12        0101 0000           0.0  s              12.4  V             39.6  °C
13        0.00  mg/h          0.00  mg/h          0.00  mg/h          0.00  mg/h
Translated on 12-08-2026, 4:29.
teileklaus
Avatar-teileklaus
Karma: +12 / -0   Thank you, like it!
2005 Volkswagen
Post21-02-2008, 10:42    Subject: Measurement Data: Complete Removal? Quote
At the Techmess (Gunningen), this is also possible, but only with number sequences without any additional characters.
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 12-08-2026, 4:30.
Post21-02-2008, 11:04    Subject: Measurement Data: Complete Removal? Quote
Hi Martin,
In the current VAG-COM version 704.1, you can select which measurement blocks (maximum of 12) to record from a list: Advanced measurement blocks are available in the control unit information, provided that a label file is stored for the respective control unit.
I've never used it, but the more measurement blocks are accessed simultaneously, the lower the sampling rate will inevitably be. It's better to know what you need and choose accordingly.
Creating a list like that gives the impression that all the measurements were taken simultaneously, but they are not. For example, it may take some time to update measurement block 12 after measurement 1 has been recorded. Therefore, I don't think this approach is very useful.
It only leads to people clicking on "everything," ultimately resulting in data that represents "a lot" while the accuracy/sampling rate approaches zero.
It's already clear that even experienced users often struggle to record meaningful data when troubleshooting. They might log irrelevant information while the engine is idling, even though the problem only occurs under full throttle, or they might select measurement blocks that have absolutely nothing to do with the actual issue.
It's like when the doctor asks about pain in your cheek, and the patient starts talking about a foot fungus they had three years ago.
See:
http://www.ross-tech.com/vag-com/tour/adv-meas-blocks.html
Translated on 12-08-2026, 4:31.
Uwe@Ross-Tech
Post22-02-2008, 2:41    Subject: Data Reset: How to Completely Clear Measurements? Quote
Can VAGCOM do that?
So, just query all relevant data points and record them with their units?
Yes, it can also query all MWB data. With an English version:
'Applications -> Controller Channels Map, then Measuring Blocks and CSV file. However, depending on the controller, it may take some time to read out all 255 blocks.'
-Uwe-
Translated on 12-08-2026, 4:34.
No new posts Pierburg MAF Sensor: Fixing Low Readings Troubleshooting & Guides
No new posts Strange readings Diesel Engine Technology
No new posts Measurement values into EDC measurement blocks On-Board Diagnostics (OBD)
No new posts Golf V TDI 1.9 BLS: Performance Data & Specs On-Board Diagnostics (OBD)
No new posts VCDS 17.8.0: Advanced Measurement Data On-Board Diagnostics (OBD)
