Document: Golf 1J, from week 48/98, Clattering noise after cold start. (Solution)
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
Michael II
Post05-03-2003, 14:39    Subject: Document: Golf 1J, from week 48/98, Clattering noise after cold start. Quote
Clattering noises after cold start
As the engine heats up, the noise becomes weaker.
Cause:
In certain cases, damage to the coating on the barrel can lead to cold spots.
Solution:
If distinct knocking sounds are detected from the engine after cold start, the following procedure should be followed:
Check oil level and oil pressure according to manufacturer's specifications.
If the oil level and oil pressure are within the normal range, further action must be coordinated with VAG product support.
TschĂŒss
Michael II
Ratings - Document: Golf 1J, from week 48/98, Clattering noise after cold start.
No new posts Doku Lupo 6X1 MJ 2001, Clattering noises after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 1J, KlappergerÀusche von Schiebedach Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 1J, KlappergerÀusche im Leerlauf Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Laderpfeiffen nach Kaltstart Diesel Engine Technology
No new posts Blue smoke video after cold start: 1.9 PD-TDI Diesel Engine Technology
No new posts Notlauf nach Kaltstart bei 1.4 TDI On-Board Diagnostics (OBD)
No new posts Notlauf nach dem Kaltstart??!? Diesel Engine Technology
