Suche Diagnoseprofi in HH | Posts 16+
Go to page: Previous  1, 2
A6 Andreas
Post23-02-2008, 20:06    Subject: Quote
Hello everyone.
You're not going to believe this, but I already bought a button!
I wanted to use it in a way that I could simulate a -40° temperature for the engine control unit shortly before starting the engine.
So, just a mechanical preheating.
But is that really the key to the whole thing?
I haven't been able to get used to it yet.
Today, I installed a second battery in parallel, but the starting speed remained the same, and the poor starting issue persists.
The problem now seems to be related to the new ESP.
I'm not sure if Audi has messed something up in the default settings.
As I mentioned earlier, possibly the starting quantity requirement.
I'm a little hesitant to adjust the basic settings.
Andreas
Translated on 01-10-2026, 2:01.
Post26-02-2008, 11:24    Subject: Quote
A6 Andreas wrote:
As I already mentioned, possibly the starting quantity specification.
I'm not really brave enough to mess with the basic settings!
Seriously: If you can't change anything about the starting speed, or if there are understandable financial reasons not to (e.g., replacing the battery, cables, or starter), then the default settings at least offer another attempt. And as long as you note the values beforehand, you can't really mess anything up while adjusting them.
Guste.
Translated on 01-10-2026, 2:03.
No new posts Looking for a repair manual Diesel Engine Technology
No new posts Audi A6 4F CAN IDs: Find them here! On-Board Diagnostics (OBD)
No new posts Circuit Diagram Search: Find Your Schematics On-Board Diagnostics (OBD)
No new posts ECU Pinout: Find Connector Pin Assignments On-Board Diagnostics (OBD)
