Golf 1J: Gear Shift Problems in Cold Weather (Solution)
Michael II
Post06-03-2003, 16:46    Subject: Golf 1J: Gear Shift Problems in Cold Weather Quote
Difficulty shifting gears when cold (shifting into 1st or 2nd gear requires excessive force when the engine is cold).
Affected gearbox assembly/unit:
DYP/EBA from 01 058 to 01 098.
ECW/DZL from 01 088 to 17 128.
EGD/ELG from 01 108 to 17 128.
Cause.
Adverse "viscosity-temperature behavior" of the transmission fluid at extremely low ambient temperatures.
Solution:
In cases of persistent complaints, the transmission oil G 052 726 A2 (1.0 l container) can be added.
Tschüss
Michael II
Translated on 31-08-2026, 6:55.
Ratings - Golf 1J: Gear Shift Problems in Cold Weather
No new posts Doku Golf 1J1214, Schaltschwierigkeiten Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J Doku: Clicking Noises (Up to KW 16/98) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Golf 1J, Door frozen to roof trim Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Coolant Leak in Cold Condition (AFN) Diesel Engine Technology
No new posts Golf ALH - Relais schaltet ständig im kalten Zustand Diesel Engine Technology
No new posts Gear Oil for 6-Speed: Fix Shifting Problems Diesel Engine Technology
No new posts Engine RPM at Cold Start: What's Normal? Diesel Engine Technology
