reuselkopp Blaumann
10-03-2008, 15:49 Subject: ZMS 038105266AQ: Fits AFN G3 Variant? |
Hello, I found a dual-mass flywheel (ZMS) on Callparts.de that might fit my Golf, but I'm not entirely sure. The part number is 038105266AQ.
Does the ZMS fit my car? Has anyone else had experience with Callparts, and what was their experience like?
Greetings.
Reuselkopp. Golf 4 Variant Modell 05, ASZ mit 330000, ERF Getriebe, mit Zwangskorken, Softwareanpassung von Alex Günther
Golf 3 Variant Modell 98, AFN mit 281000km, ASD Getriebe, VNT15 mit großer Dose, ansonsten alles Original / verkauft
Translated on 15-10-2026, 14:40.
10-03-2008, 20:18 Subject: ZMS 038105266AQ: Fits AFN G3 Variant? |
"038 xxx yyy" doesn't sound like a Golf 3!
I highly doubt that it will fit.
m; Transparency, Teamwork
Translated on 15-10-2026, 14:41.
Profile PM Garage |
kuestenkuddel Guest
10-03-2008, 21:46 Subject: ZMS 038105266AQ: Fits AFN G3 Variant? |
Hey Reuselkopp.
Just click through it yourself again; you'll find the comparison numbers there.
I would say, 'The ZMS is a perfect fit.'
http://www.autoteilebox.de/shop.html
Best regards, Kurt.
11-03-2008, 0:08 Subject: ZMS 038105266AQ: Fits AFN G3 Variant? |
What any online parts checker says is one thing.
VW states that the 038105266AQ part was never used in a G3 model, but only in the G4 model starting in 2002.
AFN has a 038, but it's the 038 105 264 J model.
Translated on 15-10-2026, 14:42.
Profile PM Garage |
kuestenkuddel Guest
11-03-2008, 0:37 Subject: Apples and Pears: A Delicious Fruit Guide |
Hi Martin,
You are comparing apples and oranges; part number 038105266AQ is a ZMS.
Your part number 038 105 264 J is correct, but it refers to a complete set, which includes the clutch disc, pressure plate, and release bearing.
Okay, so the part number 038 105 266 AQ, which is a ZMS, fits the 1.9 TDI engine with 90-101-110 horsepower.
Best regards, Kurt.
Translated on 15-10-2026, 14:43.
11-03-2008, 0:47 Subject: ZMS 038105266AQ: Fits AFN G3 Variant? |
Yes, it's possible that I was wrong.
But your 90-100-110 horsepower engines are the ALH and its variants, all from the Golf 4.
Translated on 15-10-2026, 14:44.
Profile PM Garage |
kuestenkuddel Guest
11-03-2008, 1:34 Subject: ZMS 038105266AQ: Fits AFN G3 Variant? |
Hi Martin,
http://www.rapsinfo.de/tmp/zms.jpg
Best regards, Kurt.
Translated on 15-10-2026, 14:45.
reuselkopp Blaumann
11-03-2008, 9:35 Subject: ZMS 038105266AQ: Fits AFN G3 Variant? |
According to http://webcat.zf-trading.com/, it also states that the flywheel fits my car. The flywheel has been used in many different cars. As far as I know, the AFN engine was also installed in the early G4 models, at least in the station wagon version.
Does anyone have experience with www.callparts.de?
Greetings.
11-03-2008, 11:50 Subject: ZMS 038105266AQ: Fits AFN G3 Variant? |
The AFN was only available in the G3 and 3B models (and existed there in various incompatible variations).
But not in the G4, and certainly not in the station wagon version, which came later.
Translated on 15-10-2026, 14:46.
Profile PM Garage |
