Golf 1J ABS Light: Repair Guide & Troubleshooting (Solution)
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
Michael II
Post06-03-2003, 17:16    Subject: Golf 1J ABS Light: Repair Guide & Troubleshooting Quote
ABS light is on, rear sensor cable is damaged.
Cause:
Adverse tolerances in the assembly between the sensor cable and the mounting bracket in the rear left and right fender areas. In a worst-case scenario, this can lead to damage to the sensor cable.
Check the connection of the sensor cable to the mounting brackets to ensure it is securely fastened. If the sensor cable can be easily detached from the brackets, please squeeze the brackets together by 1 mm to a maximum of 2 mm.
Tschüss
Michael II
Translated on 20-08-2026, 6:43.
Ratings - Golf 1J ABS Light: Repair Guide & Troubleshooting
No new posts Document 1J, ESP Control indicator is lit up. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document 1J up to week 38/2000, ABS control light is on. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Dashboard warning light for airbag "OFF" is constantly il... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Red LED on door lock always lit, VW Golf 3 Electrical Systems, Vehicle Electronics, Multimedia
No new posts Golf 3 TDI Synchro - Vorglühlämpchen leuchtet unterm fa... On-Board Diagnostics (OBD)
No new posts Kontrolle Kraftstofftemperatur - wie? On-Board Diagnostics (OBD)
No new posts Check KM Status On-Board Diagnostics (OBD)
