Coming Home/Leaving Home programmierbar? | Posts 16+
Go to page: Previous  1, 2
robidobi007
Post26-03-2008, 6:12    Subject: Quote
Yes, that's correct, you can adjust that setting in channel 1.
Okay, so that's the car's light, which means it only works in conjunction with a light sensor and/or the car's light switch on the Golf V.
Bora Variant 1.9 TDI PD 115PS 310Nm @ 1900 1/min
Back to top Profile PM Email
winschi
Post26-03-2008, 16:12    Subject: Quote
I tried to change the time for CH (STG 9 -> Adjustment -> Channel 1 -> Saved value 30), and I reduced it to 15, but nothing changed!
The light always stays on for about 1 minute and 30 seconds afterwards!?!?!?!?!? icon_eek.gif
mfg
winschi
robidobi007
Post28-03-2008, 12:52    Subject: Quote
The value "30" that was saved should actually represent 30 seconds. However, it's possible that this setting can only be adjusted when the switch is physically installed. But that's just a guess...
or you could just try using this encoding and see if it works.
88890F020004100000120C000000000000
Best regards.
winschi
Post28-03-2008, 17:29    Subject: Quote
It doesn't work with this encoding either!
mfg
winschi
robidobi007
Post28-03-2008, 18:18    Subject: Quote
The switch should fit without any problems... but I can't guarantee that it will work 100%, because there are too many different control units, etc. However, it's worth checking on eBay for a cheap one. If it doesn't work, you can just put the old one back in and sell it for the same price.
No new posts Polo 6R: Coming Home, Leaving Home, Door Lock Electrical Systems, Vehicle Electronics, Multimedia
No new posts Recode Coming/Leaving Lights to Fog Lights On-Board Diagnostics (OBD)
No new posts Coming-Home Logic: Old vs. New On-Board Diagnostics (OBD)
