Buying Advice: A4 Avant B6 96kw
bastion
Karma: +6 / -1   Thank you, like it!
Post10-05-2008, 16:52    Subject: Buying Advice: A4 Avant B6 96kw Quote
I am planning to buy a new car. I test-drove it today and also made a long trip. What I noticed is that he only reaches his full boost pressure around 1900 rpm, and the LMM (lambda sensor) starts to drop around 3400 rpm.
I would also be interested in typical weaknesses of the model.
Since I don't know the engine, I would like the professionals here to take a look at the log.
The vehicle is a 2002 model and has an AWX with a 5-speed manual transmission.
/my.php?image=logae1.jpg" target="_blank" class="postlink" rel="nofollow">[img][/img]
LOG-01-003-008-0121.CSV
 VCDS-Log
VCDS-Log
 File name:  LOG-01-003-008-0121.CSV
 File size:  2.03 KB
 Downloaded:  521 times
A4 Avant 08/01 AWX 05/08-
No new posts Buying guide for A4 2.5 TDI Diesel Engine Technology
No new posts Buying guide for TDI engines Diesel Engine Technology
No new posts Kaufberatung Passat 35i TDI AFN Diesel Engine Technology
No new posts Passat 3C buying guide Diesel Engine Technology
