KST 1J0 959 799 Pinout: Connector Diagram & Info
Jaxx
Karma: +0 / -2   Thank you, like it!
Post23-05-2008, 12:08    Subject: KST 1J0 959 799 Pinout: Connector Diagram & Info Quote
I have a problem: I want to connect my new 3BG rear hatch to my 3B car using the KSG (likely referring to a control unit or module), as it was originally designed.
I have reason to believe that this is possible based on the following statement:
"So, I would simply connect it the same way as it's originally done! Connect the button in the tailgate handle to the Central Locking System (CLS). The CLS then sends a signal that directly activates the actuator motor in the tailgate via a relay! This works with any 1J0 CLS, and I used the wiring diagram for a 1999 Bora Variant as a template, which also has the older CLS and electric tailgate. If you also do away with the unnecessary lock switch in the tailgate, you don't even need to run any cables through the car!"
Unfortunately, I am unable to reach the author.
Okay, so now to my question: Does anyone know which pin I need to connect the opening signal for the tailgate to, and which pin I need to use to activate the relay for the actuator motor? Or how everything else might be connected?
Please help. Thank you.
Best regards, Jaxx.
Passat 3B Variant TDI Fjordblau Bj.12/98 145PS Comfortline Epia CarPC Chip bei 230tkm und läuft und läuft... (bis jetzt 300tkm)
Translated on 04-09-2026, 9:01.
robidobi007
dieselschrauber likes this.
Post25-05-2008, 10:22    Subject: KST 1J0 959 799 Pinout: Connector Diagram & Info Quote
I found something.
23-pin connector:
old `97:
1- SW/BR - Rear window defroster.
2- BR/SW - Rear door "OPEN"
3- GE/RO - "86 S" (Fuse 37)
4- BR/GN - Kontaktschalter Schließzyl. Trunk lid.
5- SW/LI - "15" Fuse No. 6.
6- OR/BR - CAN-LOW
7- retractable/sliding roof.
8- BR/GE - Door contact for driver's side, "OPEN" position.
9- OR/GN - CAN-HIGH
10- sunroof/sliding roof.
11- GR/WS - "K" line.
12- GR/BL - "58b" - Lighting/Dimmer.
13- BR/LI - Rear hatch unlocking relay.
14 - BL/WS - "GALA"
15- BR/SW - Rear lid "OPEN"
16- BL/GR - Interior light "-"
17- LI/WS - "Crash" signal.
18- RO/BL - Interior light "+"
19- discontinued/only available for golf.
20- discontinued/only available for Golf models.
21- GR/BR - Button for rear hatch handle.
22- RO/SW - "30" Fuse, number 14.
23- BR - "31" Weight
new `99:
5- not found/missing?
6- OR/BR - CAN-LOW
9- OR/GN - CAN-HIGH
14 - BL/WS - "GALA"
19-inch wheels / only available for Golf/Variant models.
20-inch rims / only available for Golf/Variant models.
brand new `01:
1- BR/GE - Roof/Body - Door contact for driver's side, "OPEN"
2- GN/BR - Button for rear hatch handle.
3- seater / only golf.
4-
5-
6- OR/BR - CAN-LOW
7- deleted / only variant.
8- retractable/sliding roof.
9- OR/GN - CAN-HIGH
10- BR/SW - BR/SW - Rear door. "OPEN"
12- sunroof/sliding roof
13- BR/GN - Kontaktsch. Schließzyl. Trunk.
14- GR/BL - "58b" - Lighting/Dimmer.
15-
16- SW/BR - Rear window heater.
17-
18- RO/BL - Motor for releasing the tailgate lock.
19-
20- RO/BL - Interior light "+"
21- BL/GR - BL/GR - Interior light "-"
22- RO/SW - Fuse "14" (30)
Bora Variant 1.9 TDI PD 115PS 310Nm @ 1900 1/min
Translated on 04-09-2026, 9:08.
Back to top Profile PM Email
Jaxx
Post26-05-2008, 8:39    Subject: KST 1J0 959 799 Pinout: Connector Diagram & Info Quote
THANK YOU VERY MUCH. You are simply the best!
Do you also think that I should connect the opening button on the tailgate handle to PIN21?
"And I can probably connect the relay for opening (not just unlocking) to pin 13, or will the tailgate pop open if I unlock the Passat with the remote control?"
Best regards, Jaxx.
Translated on 04-09-2026, 9:15.
robidobi007
Post27-05-2008, 21:36    Subject: KST 1J0 959 799 Pinout: Connector Diagram & Info Quote
So, if I understand you correctly, then what you're saying is correct!!!
No new posts LMM Pinout: Switched Positive & Location Diesel Engine Technology
No new posts Pinout diagram for 1.7 SDI engine control unit On-Board Diagnostics (OBD)
No new posts Pinbelegung MSG 184Nm 1Z On-Board Diagnostics (OBD)
No new posts Suche Pinbelegung für ECU On-Board Diagnostics (OBD)
