Boost pressure earlier?
Rico_Avant
Post02-07-2008, 17:38    Subject: Boost pressure earlier? Quote
"Besides using a chip, how could one meaningfully adjust the boost pressure start-up on a V6 TDI AFB engine to occur earlier? Is it possible to adjust the boost pressure control valve in a way that allows it to remain open for a longer period, or to have the VTG valve activate and remain active earlier?" What happens if I turn the control rod of the VT? Will I notice a change?
bastion
Karma: +6 / -1   Thank you, like it!
Post02-07-2008, 18:36    Subject: Boost pressure earlier? Quote
If there isn't enough exhaust gas to drive the turbocharger, there will be no boost pressure.
Edit: Stay away from the VTG if you don't know what you're doing. It can quickly become very expensive.
A4 Avant 08/01 AWX 05/08-
Rico_Avant
Post02-07-2008, 21:02    Subject: Boost pressure earlier? Quote
Okay, I'm not a novice; I'm a mechanic. I was just wondering if there's any experience out there regarding this. Maybe my wording was a bit strange. What could possibly be expensive? It's not like I'm going to be revving it excessively. But it needs to work, and I think I've seen something about this somewhere before.
teileklaus
Avatar-teileklaus
Karma: +12 / -0   Thank you, like it!
2005 Volkswagen
Post02-07-2008, 21:21    Subject: Boost pressure earlier? Quote
Same as bastion.
All the older 2.5 models have this turbo lag, and the timing is normally optimally adjusted.
I can only imagine that the developing play in the shaft could be compensated for by some adjustment, allowing you to find the optimal point again.
However, this would need to be carefully controlled and monitored with a detailed LLD log, including before-and-after records and precise notes and markings of the rod.
So that you can eventually find your original, good position again, especially if things get even worse after the adjustment!
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
christians
Post04-07-2008, 12:43    Subject: Boost pressure earlier? Quote
On my old loader, I also tried adjusting the settings. However, the play wasn't in the linkage itself, but in the VTG (Variable Transmission Geometry) mechanism. Adjusting it in that case also led to stronger overshoots. It was still better than the original state.
The engine should build full boost at 1500 RPM if given enough time, for example, in 6th gear while going uphill.
Gruß Christian
Post04-07-2008, 12:49    Subject: Boost pressure earlier? Quote
"By 'expensive,' we meant that this could potentially damage larger, more delicate components. What exactly are you considering?" In the worst-case scenario, it could be the charger; it's also possible it's the LD piping; however, it's unlikely but still possible that it's the LLK.
No new posts Power Loss: Air Mass/Boost/Timing OK? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFN for early fuel injection start? On-Board Diagnostics (OBD)
No new posts Very early fuel injection start On-Board Diagnostics (OBD)
No new posts Download Pressure AFN Upload
No new posts AJM boost pressure On-Board Diagnostics (OBD)
