I think I read that the ALH has the same turbo boost pressure as the AFN? That's why I thought it was an 81 kW engine.
Okay, so it's 66 kW. I could have gotten injectors from an ALH engine, and I wanted to install them in my 1Z.
But if the ALH engine only has 66 kW, then it's not really worth it.
According to what I read in the technical article, the ALH TDI engine is 81 kW, isn't it???
I think I read that the ALH has the same turbo boost pressure as the AFN???
Hi Tim,
Did you read that somewhere here ?
If yes, please provide the exact source so that it can be corrected .
KW systems offers larger nozzles for a 66 kW system, or 7-hole nozzles that can be fitted to an existing pump housing! This will work and do what you want it to do!
Sure, here's the translation:
"gruzz mozz" translates to "greetings" or "hello" in English.
I'm currently wondering how the flow rate could possibly increase by using different nozzles.
While 66kW and 81kW engines are mechanically different only in the injectors, the EDC (Electronic Diesel Control) unit unfortunately has a different part number .
@ulf
Perhaps he read that the ALH engine is mechanically equivalent to the 81 kW engine, except for the injectors, of course... and the EDC (as mentioned above).
