Turbo Failure: Removal & Repair Guides
lars75
Post22-03-2003, 18:47    Subject: Turbo Failure: Removal & Repair Guides Quote
I drive an Audi A6 2.5 TDI, manufactured in 1999, with 105,000 km on the odometer, and I believe my turbocharger is faulty.
LLM is perfectly fine. A grinding noise occurs at speeds between 1900-2500 RPM, but only during rapid acceleration.
As soon as the noise disappears with further acceleration, the engine experiences a noticeable increase in power. The mechanism for adjusting the impeller blades is also working (and has been checked by a mechanic). Furthermore, the engine delivers its full power and can reach up to 4000 RPM on a straight highway.
What could be causing the poor performance at low speeds, the metallic grinding noise, and the uneven power delivery that is different from how it used to be?
I suspect it's the turbo.
Can anyone give me advice on how to remove the turbocharger myself, or where I can find informative technical literature or resources online?
Thank you in advance for all your answers!
lars75
Translated on 18-10-2026, 21:45.
Michael II
Post22-03-2003, 21:04    Subject: Turbo Failure: Removal & Repair Guides Quote
Hello Lars,
Was the error memory read? Did the workshop perform a test drive (target values in "Troubleshooting and Instructions")?
Tschüss
Michael II
Translated on 18-10-2026, 21:47.
No new posts Removing and cleaning a diesel particulate filter (DPF) Troubleshooting & Guides
No new posts Passat 3BG AVB - Remove bearing from Visco fan Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ARL Turbo Issues: Troubleshooting & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Turbo defective? Diesel Engine Technology
No new posts Turbo Problems? Get Turbo Repair Help Now! Diesel Engine Technology
No new posts Faulty Turbo, Mass Air Flow or Oxygen Sensor? Diesel Engine Technology
No new posts Arosa TDi: Turbo Problems, Engine Damage? Diesel Engine Technology
