Fehlercodes 01415
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post27-07-2008, 20:10    Subject: Quote
Okay, then disconnect the next connector, use a test lamp and actuator test to check the power supply, and then briefly apply 12 volts and ground to the disconnected pump to see if it starts.
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 30-07-2026, 17:10.
Geo
Post27-07-2008, 22:23    Subject: Error Code 01415: Meaning & Troubleshooting Quote
Hey, I've finally read out the data from my Touran again, and unfortunately, I found an error. unsure.gif
Address 18: Auxiliary heater
Label file: DRV\1K0-815-071.lbl
Part number: 1K0 815 071 H
Component: Auxiliary heater 031 1312.
Revision: A Serial number: 09010046
Encoding: 0000011
Operating number: WSC 01324 785 00200
Two error codes found:
01415 - Circulation pump (V55)
007 - Short circuit to ground - Intermittent.
Environmental conditions:
Error status: 00100111
Error priority: 0.
Error frequency: 12.
Lost Count: 86
Mileage: 50721 km
Time: 0.
Date: 2000-00-00
Time: 14:29:35
"aus" translates to "from" in English.
Temperature: 90.0°C
Temperature: 87.0°C
010 - Interruption/Short circuit after positive voltage - Occasional.
Error priority: 0.
Lost Count: 86
Mileage: 50721 km
Time: 0.
Date: 2000-00-00
Time: 14:29:35
Temperature: 90.0°C
Temperature: 87.0°C
Perhaps someone can tell me something about this. Based on the mileage, it must have been approximately 3 to 4 months ago.
I've temporarily deleted the error message to see if it reappears. However, I suspect it will only come back in the winter.
Geo.
Ein Mensch hat dreierlei Wege, klug zu handeln:
Erstens: Durch Nachdenken - das ist der edelste.
Zweitens: Durch Nachahmen - das ist der leichteste.
Drittens: Durch Erfahrung - das ist der bitterste.
(Konfuzius)
Translated on 30-07-2026, 17:14.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post27-07-2008, 23:19    Subject: Quote
I wouldn't wait until the winter to check those. At least, I would take a look at them and try running them with an external 12-volt wire. Are the connectors corroded?
Isn't there also a VAG-COM diagnostic function called "Actuator Test - Pump"? I need to check that.
Translated on 30-07-2026, 17:19.
Geo
Post28-07-2008, 1:39    Subject: Quote
Can you tell me where I can find the actuator test for VCDS version 805.0?
(Konfuzius)
Translated on 30-07-2026, 17:20.
Geo
Post28-07-2008, 1:40    Subject: Quote
Can you tell me where I can find the actuator test function in VCDS version PCI 805.0?
(Konfuzius)
Geo
Post28-07-2008, 2:26    Subject: Quote
teileklaus wrote:
I wouldn't wait until the warranty expires; at least I would take a look at them and try running them with an external 12-volt wire. Are the connectors corroded?
Isn't there also a VAG Com test function called "Actuator Test, Pump"? I need to check that.
Actuator test found, initially at 106%, but only briefly, then dropped to 0%.
The error reappears after being deleted.
Sunday, July 27, 2008, 7:10:10 PM: 49595
VCDS Version: DRV 805.0
Address 18: Auxiliary heating.
Control unit part number: 1K0 815 071 H.
Component and/or version: Auxiliary heater 031 1312.
Encoding: 0000011
Company number: WSC 01324
"One error found:"
010 - Interruption/Short circuit after positive terminal.
Error status: 01101010
Error priority: 0
Error frequency: 7
Lost Count: 132
Mileage: 52157 km
Time: 0.
Date: 2000.00.00
Time: 19:05:11
text
from
Temperature: 34.0°C
Temperature: 51.0°C
What now?
(Konfuzius)
Translated on 30-07-2026, 17:23.
No new posts MKB AMF Error Codes: Causes and Effects Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error Codes, Causes and Effects for MKB ASZ, AXR, ATD Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error codes and their causes for MKB AJM, ATJ, AVF, AWX Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW T4 Error Codes: Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts ASV Error Codes: Troubleshooting & Solutions Diesel Engine Technology
No new posts VAG-COM error codes On-Board Diagnostics (OBD)
No new posts Error Codes: Troubleshooting & Solutions On-Board Diagnostics (OBD)
