moby Guest
29-07-2008, 17:17 Subject: Loose Wiring in Engine Bay - Is It Normal? |
Hello, I was surprised to discover yesterday that there are two free cable guides in my engine compartment. Both are located near the two pressure valves. I have taken two pictures of them. See attachment. Can A3 drivers (facelift 8L) post a picture of the same area here? Perhaps the workshop forgot to put a cable back in during the repairs. They certainly had enough time and opportunity to do so  .
cu moby
Translated on 25-09-2026, 23:58.
moby Guest
29-07-2008, 17:19 Subject: Loose Wiring in Engine Bay - Is It Normal? |
Soooo... Diesel mechanics probably don't like larger images  cu moby.
| Description: |
| File size: |
36.6 KB |
| Viewed: |
1188 times |
| Description: |
| File size: |
56.63 KB |
| Viewed: |
1401 times |
Translated on 25-09-2026, 23:59.
g1om Guest
29-07-2008, 22:13 Subject: Loose Wiring in Engine Bay - Is It Normal? |
'I don't own an 8L model, but in my Leon, it looks exactly the same.'
It seems normal, as I've seen this type of hose package before.
matthiasTDI96 Profi-Schrauber
30-07-2008, 8:13 Subject: Loose Wiring in Engine Bay - Is It Normal? |
"Yes, it looks the same on the ASZ Golf 1J."
Translated on 26-09-2026, 0:00.
moby Guest
30-07-2008, 13:17 Subject: Loose Wiring in Engine Bay - Is It Normal? |
Hello.
Thank you for your quick responses  cu moby  .
joegolf Profi-Schrauber
Joined: 04/28/2003 Posts: 257 Karma: +3 / -0 Location: östlich von Stuttgart
30-07-2008, 16:51 Subject: Loose Wiring in Engine Bay - Is It Normal? |
The nipple is used to attach the hose of a faulty EGR valve, at least in my case  .
Golf 7 GTI
moby Guest
02-08-2008, 0:57 Subject: Loose Wiring in Engine Bay - Is It Normal? |
The nipple is used to attach the hose to a faulty EGR valve, at least in my case  .
Hi, that was good, hehe.
cu moby
