Fuel Injectors VW Golf IV AHF
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Simusas
Post05-08-2008, 10:46    Subject: Fuel Injectors VW Golf IV AHF Quote
Can someone please provide me with the part numbers for the fuel injectors of a 1998 Volkswagen Golf IV AHF?
I've had larger nozzles installed since I bought it, and now I want to replace them.
I have the following information:
3 x Nozzles 028 130 201 G.
1 x Nozzle with needle lift injector 028 130 201 J.
Can someone confirm this for me? What should I look out for when buying new nozzles?
I'd like to buy a used one if possible. Would it be okay if it has been refurbished and inspected? My Golf already has almost 200,000 kilometers on it, so I don't necessarily want to buy a new one from the dealership.
Thank you very much in advance.
Translated on 02-08-2026, 23:50.
Karma: +438 / -0   Thank you, like it!
Post05-08-2008, 11:01    Subject: Fuel Injectors VW Golf IV AHF Quote
You don't need to replace the entire injectors. It is sufficient to replace just the injector nozzles. These are the only wear items and also the only difference between different engine types or tuned vs. non-tuned engines.
"Personally, I wouldn't buy used injectors because they are usually only replaced when they have very high mileage and a correspondingly poor spray pattern, or when someone is trying to sell them on eBay. To overhaul such injectors, the injector nozzle needs to be replaced, and the opening pressure needs to be readjusted."
You can find the injector nozzles, including the adjustment settings, here at the Dieselschrauber shop (shop.dieselschrauber.de).
Translated on 02-08-2026, 23:52.
No new posts Einstellung der Einspritzdüsen/Düsenhalter eines VP-TDI Troubleshooting & Guides
No new posts Replacement of injector nozzles/holders on a VP-TDI Troubleshooting & Guides
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Einspritzdüsen Golf IV Motor AHU und ALH 90 PS Diesel Engine Technology
No new posts Fuel Injectors VW Golf IV ALH Manual to Automatic Diesel Engine Technology
No new posts Fuel Injectors AKN - Buy Now! On-Board Diagnostics (OBD)
No new posts Einspritzdüsen vom 150 PS TDI in 100 PS TDI!!! Diesel Engine Technology
