Spritzventil: Tastverhältnis optimieren
HHdieselpowerHH
Karma: +1 / -1   Thank you, like it!
Post11-08-2008, 21:14    Subject: Spritzventil: Tastverhältnis optimieren Quote
hello everyone,
What is the minimum acceptable value for the injection timing (dwell time) for a fuel injector on an A6 2.0 TDI V6 180ps with engine code AKE? Is it possible that the value fluctuates between 30%, 42%, and 29% when the engine temperature is 85 degrees Celsius, and what could be the cause of this fluctuation?
Sure, here's the translation:
"P.S.: By "value," I mean the value in field 4 of measurement block 08."
Best regards, Harry.
Translated on 18-08-2026, 0:46.
christians
Post12-08-2008, 11:40    Subject: Spritzventil: Tastverhältnis optimieren Quote
Under what conditions? It's normal during operation, and there isn't a fixed value, but it shouldn't be at its maximum or minimum limits (5% or 95%).
Gruß Christian
Translated on 18-08-2026, 0:47.
HHdieselpowerHH
Post12-08-2008, 17:43    Subject: Spritzventil: Tastverhältnis optimieren Quote
idling.
Translated on 18-08-2026, 0:48.
No new posts Boost Control Valve Airflow Ratio Diesel Engine Technology
No new posts Boost Valve Airflow Ratio Explained On-Board Diagnostics (OBD)
No new posts Key Ratio: Clarification Diesel Engine Technology
