T4 2.5 TDI: Starting Problems & Solutions
sunseeker222
Post02-09-2008, 20:23    Subject: T4 2.5 TDI: Starting Problems & Solutions Quote
Hello everyone,
I have a friend's 1996 T4 bus with a 2.5 TDI engine (102 hp) parked in my yard.
The little car simply won't start; the preheating lamp is only very dim. My first thought was the ignition switch, so I replaced it, but unfortunately, the problem persists. I also replaced the preheating relay, but that didn't solve it either. The fuse for the preheating system is also okay.
Does anyone have any other suggestions for me? I've read about similar problems before, but I haven't found a suitable solution.
I would have guessed it was an ESP issue, but the faintly glowing preheating indicator light is confusing me.
Thank you very much for your help!
Translated on 14-10-2026, 7:22.
christians
Post03-09-2008, 12:35    Subject: T4 2.5 TDI: Starting Problems & Solutions Quote
If the battery is too weak, it might not be able to provide enough power for the engine to reach the speed needed to start.
Gruß Christian
Translated on 14-10-2026, 7:23.
sunseeker222
Post03-09-2008, 13:25    Subject: T4 2.5 TDI: Starting Problems & Solutions Quote
Unfortunately, that's not the reason either; it would have been too good to be true.
Translated on 14-10-2026, 7:24.
sunseeker222
Post03-09-2008, 15:23    Subject: T4 2.5 TDI: Starting Problems & Solutions Quote
Okay, I've found the errors.
The dimly lit preheating lamp was caused by a faulty relay number 109 in slot 3.
For this reason, the MSG was without power.
Maybe this will help someone icon_wink.gif someday.
No new posts Occasional starting problems with the Lupo 1.4 TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document startup issues, adjusting initial quantity Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Starting problems and glow plug system issues in TDI engi... Technical Articles
No new posts AHF Starting Problems: Troubleshooting Guide Diesel Engine Technology
No new posts Starting Problems: Troubleshooting & Solutions On-Board Diagnostics (OBD)
No new posts Audi A6 TDI Starting Problems: Common Causes Diesel Engine Technology
No new posts ALH Engine Starting Problems: Troubleshooting Guide Diesel Engine Technology
