AFN Injectors: Compatible with AHF Engines?
Uwe
Post23-03-2003, 21:43    Subject: AFN Injectors: Compatible with AHF Engines? Quote
Hi!
"I found a set of fuel injectors at a good price. The part numbers are: 028 130 201 T and 028 130 201 S, which are needle lift injectors. They are intended for an AFN engine. However, I need injectors for an AHF engine, which is quite similar to the AFN. The part numbers are not identical. Do you think they might still fit? And what is the difference between them? Are there perhaps suitable injectors from Daimler-Chrysler?"
Uwe
Kundenservice bedeutet bei Audi, die Kunden so schnell über den Tisch zu ziehen, daß sie die Reibungswärme als Nestwärme empfinden!
Translated on 23-08-2026, 15:32.
Thomas
Post25-03-2003, 14:13    Subject: Fuel Injectors: Types, Function & Replacement Quote
Theoretically, they are the same. I think you can use them without any problems.
I don't know if Daimler produces anything like that.
Greetings.
Thomas.
Audi S2 ADU Bj. 1993
Audi A3 TDI ASZ Bj. 2001
Translated on 23-08-2026, 15:33.
Uwe
Post25-03-2003, 20:17    Subject: AFN Injectors: Compatible with AHF Engines? Quote
Hi!
Aber warum haben sie dann andere Teile-Nummern? Vielleicht ist das Einspritzbild oder der Öffnungsdruck anders? Who has advice?
Uwe
Translated on 23-08-2026, 15:34.
Post25-03-2003, 21:45    Subject: Generational Differences: Understanding the Gap Quote
Uwe wrote:
But why do they then have different part numbers? Perhaps the injection molding process or the opening pressure is different? Who knows the answer???
Hi Uwe,
AFN is one generation older than AHF.
They also have different pumps, as far as I know - in short, the entire injection system is probably tuned differently in detail.
Does the AHF already have Euro 3 emissions standards? The AFN certainly only has Euro 2.
Translated on 23-08-2026, 15:35.
Uwe
Post25-03-2003, 22:28    Subject: AFN Injectors: Compatible with AHF Engines? Quote
"I don't like experiments like that. Since it's not clearly stated whether I can use these nozzles, I'd rather avoid them and buy the expensive, perfectly matching ones from a reputable supplier."
@Ulf
Mine is the Euro 3 version and I believe it's the successor to the AFN, just like you said.
Thank you and best regards.
Uwe.
Translated on 23-08-2026, 15:36.
haehnlein
Post25-03-2003, 22:34    Subject: AFN Injectors: Compatible with AHF Engines? Quote
Uwe wrote:
Please buy me the expensive, perfectly fitting ones from the reputable dealer.
no icon_exclaim.gif Call the bakery "Boller" in Wiesbaden: 0611422031 icon_exclaim.gif
____________
Kein Auto mehr!
Translated on 23-08-2026, 15:37.
Uwe
Post25-03-2003, 22:39    Subject: AFN Injectors: Compatible with AHF Engines? Quote
Okay, thanks! I emailed Nassi, but he only has the rates for AFN. I'll check with the company "Boller" in Wiesbaden and see what they charge.
Can you put it in for me?
Uwe
Translated on 23-08-2026, 15:38.
haehnlein
Post25-03-2003, 23:25    Subject: AFN Injectors: Compatible with AHF Engines? Quote
Uwe wrote:
Okay, I will do that. Thanks! I emailed Nassi, but he only has the ones for AFN. I'll check with the company Boller in Wiesbaden. Let's see what they charge for the set.
Can you put it inside me?
Hi Uwe,
"Do it... they have fair prices (certainly 120 euros cheaper for nozzles) icon_exclaim.gif. Things are very difficult for me until the end of April icon_cry.gif, but I can help you in May!"
Best regards, Christian.
____________
Kein Auto mehr!
Translated on 23-08-2026, 15:39.
tim27
Post26-03-2003, 7:46    Subject: Best German Shepherd Breeders: Find Yours Now! Quote
Hi Uwe,
I might be able to use the nozzles for the AFN if you still have them.
Please send me an email letting me know what you want and how much you're willing to pay. Thank you.
[email protected]
Translated on 23-08-2026, 15:40.
zzzZZ
Post26-03-2003, 8:55    Subject: AFN Injectors: Compatible with AHF Engines? Quote
Short question: Are we talking about the parts on eBay (seller auditom2)? Is someone among you currently bidding on them? Otherwise, I'm considering buying them.
Translated on 23-08-2026, 15:41.
Thomas
Post26-03-2003, 8:58    Subject: Fuel Injectors AFN/AHF - Buy Now! Quote
I checked in the AKTE system yesterday, and it shows that the injectors for the AFN and AHF engines have the same part number. icon_smile.gif Only the injector with the NHG code has an additional "X" at the end.
I think that probably says more about the year it was manufactured, or whether the nozzle is new or has been replaced. However, I can't confirm that with certainty.
Greetings.
Thomas.
Translated on 23-08-2026, 15:42.
Michael II
Post26-03-2003, 9:17    Subject: AFN Injectors: Compatible with AHF Engines? Quote
"X" refers to interchangeable nozzles. The part numbers are the same for both AFN and AHF models.
028 130 201 T for standard nozzles.
028 130 201 S for NHG.
Tschüss
Michael II
Translated on 23-08-2026, 15:43.
Thomas
Post26-03-2003, 9:29    Subject: AFN Injectors: Compatible with AHF Engines? Quote
Hello again,
Now that's been clarified, when you replace the injectors, do you always replace those copper seals between the injector and the cylinder head?
Greetings.
Thomas.
Translated on 23-08-2026, 15:44.
Michael II
Post26-03-2003, 9:49    Subject: AFN Injectors: Compatible with AHF Engines? Quote
Hello Thomas,
I always exchange them.
Tschüss
Michael II
haehnlein
Post26-03-2003, 12:49    Subject: AFN Injectors: Compatible with AHF Engines? Quote
Thomas wrote:
Now that's been clarified, do you actually replace those copper seals between the injector nozzle and the cylinder head every time you change the nozzles?
Hi Thomas,
That's the only item costing just one cent at VW, so you should probably replace it as a precaution. However, I've also installed those rings twice before... then you have to turn them around icon_rolleyes.gif.
____________
Kein Auto mehr!
Translated on 23-08-2026, 15:45.
Uwe
Post26-03-2003, 18:15    Subject: AFN Injectors: Compatible with AHF Engines? Quote
@René and Tim,
I don't have the nozzles yet; I have several offers under consideration, one of which is from eBay, and another from an eBay seller who isn't currently offering them on the platform.
Offers like these pop up from time to time, so don't panic.
@MichaelII
Thank you for the information!
Uwe
Translated on 23-08-2026, 15:46.
No new posts Einstellung der Einspritzdüsen/Düsenhalter eines VP-TDI Troubleshooting & Guides
No new posts Replacement of injector nozzles/holders on a VP-TDI Troubleshooting & Guides
No new posts 1Z ESPs compatible Diesel Engine Technology
No new posts Audi SYMPHONY 2 in A4 B5 kompatibel? Electrical Systems, Vehicle Electronics, Multimedia
No new posts GRA Connector Not Compatible: Troubleshooting & Fixes Diesel Engine Technology
No new posts Incompatible NIC: Troubleshooting & Solutions On-Board Diagnostics (OBD)
