TÜV and Chip: What You Need to Know
windl
Post21-03-2003, 7:54    Subject: TÜV and Chip: What You Need to Know Quote
For your information.
'Last week, I took my TDI to the TÜV (German technical inspection agency). During the inspection, they also checked the engine control unit. I think they were trying to see if there was a tuning box or something similar hidden inside, or whether it had been opened before (is that even visible?).'
Translated on 18-08-2026, 18:22.
mozz
Post21-03-2003, 9:53    Subject: TÜV and Chip: What You Need to Know Quote
"Um genau zu sein, was meinst du mit 'kann man das von außen sehen?' - Nein, because it would really take someone to make deep scratches into the control unit with a screwdriver for it to be noticeable on the housing. Unless, of course, some tuner has stuck a large sticker onto the control unit!"
You can see such an intermediary if you look closely!
Sure, here's the translation:
"Hi, how are you?"
Translated on 18-08-2026, 18:23.
Post21-03-2003, 14:44    Subject: TÜV and Chip Tuning: Legal or Illegal? Quote
windl wrote:
During the inspection, he also looked at the control unit.
Hi.
Did the man really remove the plastic engine cover to access the engine control unit?
Or which control unit are you referring to?
Translated on 18-08-2026, 18:24.
windl
Post27-03-2003, 7:59    Subject: TÜV: Your Guide to Vehicle Inspection & Safety Quote
He removed the rubber seal in the middle, near the windshield wipers. I can't imagine he did it to better see the vehicle identification number, since there's a viewing window for that. Then, he shone a flashlight inside and seemed to be poking around. It just occurred to me that maybe he was looking at the control unit (ECU)!
Translated on 18-08-2026, 18:25.
kenny
Post27-03-2003, 10:03    Subject: TÜV and Chip: What You Need to Know Quote
He compared the vehicle identification number with mine. Can you actually see the control unit through the viewing window? It's a small, silver (sometimes black) box.
No new posts Tuning comparison: Chip vs. Powerbox Technical Articles
No new posts Chip Tuning 115 PS - Performance Upgrade Diesel Engine Technology
No new posts AFN Chip: What it is and how it works On-Board Diagnostics (OBD)
No new posts AFN Timing Belt & Chip Replacement Diesel Engine Technology
No new posts new chip Diesel Engine Technology
