Tobi12345 Blaumann
Joined: 03/29/2005 Posts: 151 Karma: +2 / -0 Location: nähe Hamburg
29-09-2008, 16:34 Subject: KPerformance: Troubleshooting and Solutions |
A friendly hello to everyone.
"Recently, I've been having a problem where KPerformance won't run. I can open it, but when I press the button to start the measurement, I always get a message saying that the program is no longer working correctly and is therefore being stopped. Also, the VCDS feature "Acceleration" (which also measures acceleration) is not working either."
I've already tried disabling the firewall, but it didn't help.
I'm using a laptop with Vista, and I've already performed measurements using KPerformance, but with an older version.
VAG-COM.
Have you experienced anything similar? Do you have any solutions or suggestions? Or does anyone have a tip as to what might be causing this?
Thank you all, and have a pleasant evening.
Best, Tobi.
A6 Avant 3,0TDI Tiptronic Bj. 02/2008
Translated on 17-09-2026, 4:19.
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
29-09-2008, 18:26 Subject: KPerformance: Troubleshooting and Solutions |
What version of VCDS is being used, and what is its data version?
What exactly are the error messages for both actions? Screenshots would be best.
Translated on 17-09-2026, 4:20.
Profile PM WWW Garage |
Tobi12345 Blaumann
29-09-2008, 19:14 Subject: KPerformance: Troubleshooting and Solutions |
Hi Rainer, and thanks for taking on this matter.
Here are the screenshots, as promised!
Okay, before I forget, regarding the acceleration feature in VCDS, it shows...
Please provide a Screenshot of the image that appears immediately after pressing the start button.
Best, Tobi.
| Description: |
 Download |
| File name: |
Fehlermeldung KPerformance.doc |
| File size: |
642.5 KB |
| Downloaded: |
537 times |
| Description: |
 Download |
| File name: |
Datenstand VCDS.doc |
| File size: |
722 KB |
| Downloaded: |
552 times |
Translated on 17-09-2026, 4:21.
Tobi12345 Blaumann
29-09-2008, 19:15 Subject: KPerformance: Troubleshooting and Solutions |
Oops, I think my finger hit "send" too early.
Steffen W Profi-Schrauber
Joined: 07/05/2008 Posts: 1276 Karma: +104 / -0 Location: Altenburg
30-09-2008, 15:07 Subject: KPerformance: Troubleshooting and Solutions |
Then I'm not alone.
I'm experiencing the exact same problem. My laptop is a Fujitsu Siemens Amilo with Vista. I'm using the latest USB version of VCDS from Rainer. I've already reinstalled Vista without any security software (unfortunately, I couldn't install XP), and it still doesn't work. I'll try running it in safe mode on my way home today.
Passat Variant BGW 2005
Translated on 17-09-2026, 4:22.
01-10-2008, 17:02 Subject: KPerformance: Troubleshooting and Solutions |
It doesn't work even in safe mode. It's probably a problem with Vista.
04-10-2008, 6:04 Subject: KPerformance: Troubleshooting and Solutions |
For Rainer, for potential fixes in later versions:
In Safe Mode on Vista Home Premium, when you click on...,
"Press the 'start' button." "API server not found" or similar.
In safe mode with network drivers, as well as in normal mode, the error message "Application failed to start" appears, along with an address indicating a protection violation.
It starts without any problems on the stationary computer in the garage, which is running Windows XP. However, that computer is stationary.
The XP installation failed on the laptop. I thought it would be the easiest thing to do. When starting from the XP CD, the setup doesn't find any installed hard drive. It might be worth trying to use Partition Magic and wiping Vista first. However, if it still doesn't work, and I don't know if it will, I won't have an operating system. I didn't get a CD for Vista. I only have a recovery tool for backing up and restoring HD images, but that will be gone if I format the drive.
Before I jump into the deep end and just try it, I'll test the network settings in Vista one more time. I'll get back to you.
Translated on 17-09-2026, 4:24.
04-10-2008, 9:08 Subject: KPerformance: Troubleshooting and Solutions |
Please unpack this KPerformance.exe file and place it in the plugins directory.
If it crashes again, please take a Screenshot of the Windows error message, including the addresses.
The "normal" Vista mode is fine.
The error is definitely in the program; I'm just not entirely sure yet where the problem lies.
| Description: |
 Download |
| File name: |
KPerformance.rar |
| File size: |
586.45 KB |
| Downloaded: |
597 times |
Translated on 17-09-2026, 4:25.
Tobi12345 Blaumann
04-10-2008, 11:14 Subject: KPerformance: Troubleshooting and Solutions |
Hi Rainer!
Okay, I'm going to get started on this now. Should I delete anything from the "Plugins" folder beforehand, or does VCDS automatically copy the newly added files?
Best, Tobi.
Translated on 17-09-2026, 4:26.
04-10-2008, 12:11 Subject: KPerformance: Troubleshooting and Solutions |
Well, the program name is the same, so the .exe file will overwrite the existing one. Since the old .exe file doesn't work for you anyway, you don't need to back anything up.
Translated on 17-09-2026, 4:27.
Tobi12345 Blaumann
04-10-2008, 14:35 Subject: KPerformance: Troubleshooting and Solutions |
It's working again!!!
Thank you for the support. So, was the problem related to Vista? Will I likely experience something similar with the VCDS feature acceleration?
But that doesn't really matter, because Ross-Tech will probably fix the bug in the next software update.
It's important to me that your plugin is working again.
Thank you very much, and I hope you have a nice weekend.
Best, Tobi.
04-10-2008, 15:39 Subject: KPerformance: Troubleshooting and Solutions |
I confirm: Mine is working again too!
Everything is fine, and thank you again.
Translated on 17-09-2026, 4:28.
04-10-2008, 16:28 Subject: KPerformance: Troubleshooting and Solutions |
Great, thanks for the feedback! I'll go ahead and create a version without debug information.
Vista exhibited a slightly different behavior in its messaging, which revealed a bug in the display class.
Translated on 17-09-2026, 4:29.
