Adjusting the fuel injection start with VAG-COM?
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Hans Baldauf
Post23-10-2008, 21:57    Subject: Adjusting the fuel injection start with VAG-COM? Quote
When using the TDI Graph, three lines are visible.
In which area is an early injection point located?
Above or below the ideal line?
What values does the 10-digit measurement block "000" display?
Sincerely,
Hans
Steffen W
Karma: +104 / -0   Thank you, like it!
Post24-10-2008, 19:38    Subject: Adjusting the fuel injection start with VAG-COM? Quote
MWB 000:
Value.
1 = Engine speed.
2 = Start of funding.
3 = Accelerator pedal position.
4 = Injection quantity.
5 = Intake manifold pressure.
6 = atmospheric pressure.
7 = Coolant temperature.
8 = Intake air temperature.
9 = Fuel temperature.
0 = Air mass.
Passat Variant BGW 2005
It's early up there.
Hans Baldauf
Post24-10-2008, 20:48    Subject: Adjusting the fuel injection start with VAG-COM? Quote
Hello Werner, hello Rainer,
Thank you for your factual and objective responses.
I am (for now) completely happy and content.
Hans.
No new posts Adjusting timing and PD element for common rail diesel en... Troubleshooting & Guides
No new posts V6 TDI: Adjust Injection Timing with VAG-COM On-Board Diagnostics (OBD)
No new posts Dynamically check and, if necessary, adjust the start of ... On-Board Diagnostics (OBD)
No new posts Audi A6 TDI: Adjusting Fuel Injection Timing Diesel Engine Technology
No new posts V6 TDI AKN issues with setting the injection timing using... On-Board Diagnostics (OBD)
