1.9 TDI AFN Engine, does not preheat and over-oils
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Ashanti06
Post24-11-2008, 11:20    Subject: 1.9 TDI AFN Engine, does not preheat and over-oils Quote
Hello everyone...
I have here a Seat Alhambra 1.9 TDI AFN, manufactured in 1997.
For about two weeks, the engine has not been starting. Using the long starter cord, the vehicle was able to be started. If the water temperature sensor was disconnected, it would start to glow approximately 30 seconds before it came loose without any problems.
Currently, the problems have expanded, meaning the vehicle is no longer starting. It can only be moved by dragging, extremely sticky.
We have replaced the water temperature sensor up to now. We have also replaced the engine control unit. Motor to control unit wiring checked and control unit wiring, relay, fuse, and ground point wiring checked, everything is OK.
The old engine control unit indicated an error message: "Control unit defective."
The new control unit does not detect any errors; the measured values for water temperature, fuel temperature, and intake air temperature are correct.
Who has any further suggestions for where to look?
Thank you in advance
Ashanti06
mserge
Post24-11-2008, 16:52    Subject: 1.9 TDI AFN Engine, does not preheat and over-oils Quote
Do you have voltage on the light bulbs, i.e., are they actually glowing?
Does the starter spin fast enough? A TDI needs a minimum starting speed, otherwise it won't start. Given the age of the car, I could easily imagine that the starter motor is to blame.
neuer Turbo bei 200.000km
neue ESP bei 216.000km
verkauft mit 225000tkm
Clio 2 RS 170 PS BJ2003
mserge
What do you mean by over-oiling?
Does he smoke black tobacco or something?
Ashanti06
Post24-11-2008, 17:18    Subject: 1.9 TDI AFN Engine, does not preheat and over-oils Quote
By "overfueling," I mean that there is so much fuel that even with pre-heating, only white smoke comes out and it doesn't start. My opinion is that the starter doesn't affect the pre-heating process. When I turn the starter, it seems to spin fast enough.
What measurement values are necessary for the control unit to enable preheating?
Post24-11-2008, 18:19    Subject: 1.9 TDI AFN Engine, does not preheat and over-oils Quote
Coolant temperature must be below 5°C, therefore check block 7 in the engine.
If you're already at it, you can also use the TDI timing checker to check the injection start. Not that the timing/injector position is incorrect and the injection timing is not correct.
Hello, Rainer
BM
Avatar-BM
Post24-11-2008, 18:24    Subject: 1.9 TDI AFN Engine, does not preheat and over-oils Quote
Not that the timing/injector position is incorrect and the injection timing is off.
Yes, and there is also the KW - gear. Is the pulley still running smoothly?
3B5 AJM
No new posts DPF not regenerating Troubleshooting & Guides
No new posts 2.7l V6 CR-TDI, Anpassungskanäle funktionieren nicht Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Not LLM: Poor Performance Explained. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Passat 3BG 1.9 TDI not starting/won't start due to glow p... Diesel Engine Technology
No new posts Motor glüht nicht mehr vor, was ist da los? Diesel Engine Technology
No new posts VW V6 TDI: Glow Plug Issues & Solutions Diesel Engine Technology
No new posts Touran 1,9l TDI glüht nicht vor bei Minus 15°C Umgebung... On-Board Diagnostics (OBD)
