Login Code: Generate & Verify Secure Access
gt1964
Post27-11-2008, 20:27    Subject: Login Code: Generate & Verify Secure Access Quote
Hello everyone.
I'm having the following problem: Passat 3B, engine code AHU.
I wanted to lower the idle speed a bit (currently 970 RPM). Login code: 12233.
Unfortunately, it doesn't work. The control unit is blocked for about 3 minutes because of an incorrect code.
"Translate the following text from German to English. Provide ONLY the translation, no explanations."
"Do the same with 26262."
Is there another option?
Translated on 29-10-2026, 7:23.
Wiesel
Post28-11-2008, 8:28    Subject: Login Code: Generate & Verify Secure Access Quote
What is the part number for the MSTG?
Which diagnostic adapter or tool?
Possibly - which VAG-COM / VCDS version?
Best regards, Micha.
Translated on 29-10-2026, 7:24.
gt1964
Post28-11-2008, 14:52    Subject: Login Code: Generate & Verify Secure Access Quote
Hi Micha,
Control unit.
Part number: 038 906 018 N
Component: 1.9L R4 EDC, part number 00AG 1615.
VCDS version: DRV 805.1
Data as of: 20081010.
chli1976
Post28-11-2008, 17:00    Subject: Login Code: Generate & Verify Secure Access Quote
Normally, no login is required to change the idle speed.
VCDS
Translated on 29-10-2026, 7:25.
Wiesel
Post28-11-2008, 20:47    Subject: Login Code: Generate & Verify Secure Access Quote
If the vehicle has the original data set, the login is 12233!
 File size:  2.87 KB
 Viewed:  2325 times
gt1964
Post28-11-2008, 20:53    Subject: Login Code: Generate & Verify Secure Access Quote
According to the previous owner (first owner), nothing unusual has been done to the car (I know him quite well), but unfortunately, 12233 is not possible.
Translated on 29-10-2026, 7:26.
Wiesel
Post28-11-2008, 21:02    Subject: Login Code: Generate & Verify Secure Access Quote
You could try checking if the logins for GRA activation (11463) and...
Deactivation (16167) works (disable after login, then enable).
(to control). If they leave, the number 12233 was changed, which only applies to that specific unit.
This is achieved by soldering in modified memory modules.
gt1964
Post29-11-2008, 12:26    Subject: Login Code: Generate & Verify Secure Access Quote
I'll try to do it. However, I won't be able to get to it until next week, as the car is currently being driven. I'll let you know how it looks then.
Thank you for your efforts.
Translated on 29-10-2026, 7:27.
No new posts Golf 3 STG Login Code: 1996 Model On-Board Diagnostics (OBD)
No new posts EDC login code Diesel Engine Technology
No new posts Spare key with 4-digit code On-Board Diagnostics (OBD)
No new posts Radio Code: How to Find & Set It Diesel Engine Technology
