Engine Problems: Common Causes & Solutions
tino
Post02-04-2003, 15:17    Subject: Engine Problems: Common Causes & Solutions Quote
hello,
I'm having a small problem with my Passat TDI 90hp, manufactured in 1996.
The issues are: loss of power, rough idling (misfiring), stalls when idling, and jerky operation.
It's not the mass airflow sensor, and I'm not sure what else it could be.
Thank you for your help.
best regards
tino
Translated on 26-09-2026, 22:30.
joergs
Post02-04-2003, 16:46    Subject: Engine Problems: Common Causes & Solutions Quote
Try using the search function! There should be plenty of information about performance issues and stuttering.
Translated on 26-09-2026, 22:31.
Post03-04-2003, 9:27    Subject: Engine Problem: Troubleshooting & Solutions Quote
tino wrote:
...it stalls when idling...
What does the transparent hose between the diesel filter and the fuel injection pump indicate? Are there air bubbles or foam inside?
tino
Post03-04-2003, 16:44    Subject: Engine Problems: Common Causes & Solutions Quote
hello
The hose is normally filled with diesel, not foam or a diluted mixture.
best regards
tino
Translated on 26-09-2026, 22:32.
Post03-04-2003, 17:01    Subject: Engine Problems: Common Causes & Solutions Quote
tino wrote:
tag
The hose is normally filled with diesel, not foam or a pale substance
Hi.
Then, take a look at the technical article on troubleshooting with VAGCOM; it lists several possible causes for power loss.
Your error description is a bit too general to provide a more specific suggestion.
Translated on 26-09-2026, 22:33.
tino
Post04-04-2003, 7:41    Subject: Engine Problems: Common Causes & Solutions Quote
'Thank you.'
Thank you for your efforts. I found the problem; it was the fuel injection pump.
I already have a new one.
See you soon.
tino
Post04-04-2003, 8:02    Subject: Engine Problems: Common Causes & Solutions Quote
tino wrote:
thank you
for your efforts, I have found the error; it is/was the fuel injection pump
Hi Tino.
Can the error be described in more detail (what is broken in the pump)?
For general knowledge and experience enhancement...
Translated on 26-09-2026, 22:34.
