AVR: 5 Identical Pistons - Explained
vwSchrauber
Karma: +42 / -0   Thank you, like it!
Post22-01-2009, 10:26    Subject: AVR: 5 Identical Pistons - Explained Quote
According to the spare parts catalog, the AVR (2.5 R5 with 80/109) has 5 identical pistons. This is unusual compared to other similar five-cylinder engines like the ANJ or APA, as it would mean that the intake and exhaust valves on the AVR would always be located on the same side. Alternatively, the valves could be recessed in the cylinder head, which would eliminate the need for valve pockets.
The replacement sets with the rings are the same again.
It is not possible to make any statements about the shape of the cavity, but the nozzles have a different part number.
Does anyone know what's being played?
"Thank you."
John.
Translated on 24-08-2026, 18:41.
No new posts Tuning Specs: Same Software? Diesel Engine Technology
No new posts LMM with different part numbers for the same vehicle? Diesel Engine Technology
No new posts 3 mal AFN und das gleiche problem bei 2300-3000 Umin Diesel Engine Technology
No new posts LM3 vs. VAG: Different Bosch Numbers? Why? Diesel Engine Technology
