I just updated to version 805.2 and have been driving around the area for about 20 minutes.
03G 906 018 EM 1881 and blocks 070, 069, and 068.
After a few minutes, the middle block disappeared, so I reactivated it with "Start," and a few minutes later, the third block also disappeared.
There are probably some how-to guides to avoid that.
Is this a Dell M4300 running Windows XP Professional, and is McAfee disabled?
I experienced similar crashes frequently during the summer when I was trying to log 13 hours with a Dell D800 running Windows 2000. However, it seemed to be related to the laptop itself, as it worked fine if I didn't close the lid.
I'm new to using the M4300, especially the fact that I was able to watch the process.
As I mentioned, with the D800 in the summer, I could see the need for the folding mechanism.
Today, on the M4300, I didn't manage to get anything done.
I selected those three sections and then just watched (and drove).
At some point, one of the blocks was removed.
Are there any typical services that might interfere with USB communication?
You could turn it off.
